Clutch issues
Here's whats going on. I replaced the clutch and brake levers myself a few weeks ago, nothing went wrong, everything worked fine. I've put several hundred miles on it since then with no issues. Today, I went for a quick ride, about 15 miles or so, but it started to look like rain so I came back home, parked in front of my house and sat on the porch for a bit while pulling up the weather radar on my phone. Decided it was looking a bit sketchy and the window to ride was very slim, so I rode down to the end of my street and turned into my alley so I could park it in the garage. Get in front of my garage and I can't get it in neutral. Just bypasses it completely, goes into first easily enough, 2nd takes some effort with no grinding, but neutral is not there. Whatever. So I shut the bike off and go open the gate and garage door, fire it back up and ride into the garage. Still can't get it into neutral. Matter of fact, I've noticed even with the clutch in all the way in first gear, the bike is creeping forward slightly. Shut it off, and I can get into neutral easily. Fire it back up, same deal, neutral isn't there, and it creeps very slightly in first.
Primary fluid was changed earlier this summer, may only have 1000 miles on it. Clutch doesn't feel like it's slipping at all to me, it just feels like it's not disengaging all the way in my mind.
So my questions are: Is the tell tale symptoms of a clutch needing adjustment? Or is this ominous signs of a clutch going out? Clutch adjustment something I can handle without a service manual? I work on cars for a living, so turning a wrench is what I do all day, just new to bikes.
On a big twin you turn it till you feel resistance and then turn it an additional 1/2 to 1 turn, that is not correct for a Sportster.... need to buy a manual.....
You are correct I was trying to think and type.....
