2002 883 float leak
Old Nov 5, 2019 | 06:31 PM
Krumby's Avatar
Krumby
Default 2002 883 float leak
Aloha I have a 2002 883 with Kevin carb overflow was pouring gas out so I took it apart and cleaned the carb and everything else and put a new needle valve in. There was a good amount of dirt in the bowl which I also cleaned out. The floats were dry and had no fuel in them. I ran some gas through the carb before putting it back together and now it still pours out the over flow.
What else should I check replace ????
Mahalo for the help
Old Nov 5, 2019 | 07:58 PM
John Harper's Avatar
John Harper
Did you make sure the needle valve is the same length as the old one? There are two types. My rebuild kit had the wrong one so I had to re-use the old one, not a problem so far.
Did you check the needle seat for a "booger" keeping the needle from a good seal?
I assume you checked float height, so that's probably not an issue.
John
Old Nov 5, 2019 | 08:07 PM
mmesa005's Avatar
mmesa005
Some things to check (from my CV carb manual)
OVERFLOW
Check for: Remedy:
1. Restricted fuel tank vent system. 1. Correct restricted hose. Replace vapor vent valve.
2. Loose float bowl screws. 2. Tighten screws.
3. Damaged float bowl O-ring. 3. Replace O-ring.
4. Damaged or leaking float assembly. 4. Replace float assembly.
5. Particle contamination in fuel inlet fitting cavity. 5. Clean and clear cavity and fuel supply tract.
6. Worn or dirty inlet valve or seat. 6. Clean or replace valve and clean seat.
7. Improper fuel level in float bowl. 7. Adjust float tab for correct fuel level.
Another thing if the above doesn't solve the problem
Old Nov 5, 2019 | 09:25 PM
Midpegs's Avatar
Midpegs
When this happens it is often caused by tiny flake of dirt that is lurking just behind the float valve seat . When you remove and invert the carb to clean and inspect it the dirt falls back down the fuel feed . But when you put it all together and put it back on the bike the fuel flushes the dirt particle back into the valve seat and the needle can't shut off the fuel . I have encountered this scenario a few times over the years and it's very frustrating but the only cure is to have the carb off again , remove the float needle and blast some carb cleaner up through the valve seat .
Old Nov 6, 2019 | 12:23 AM
Krumby's Avatar
Krumby
Default Guess I need to dig deeper
I checked the needle verses the old one and they looked the same. I cleaned everything up and ran some gas through the card before putting it all back together. Not sure why it’s leaking I didn’t check the float level but there was no gas in the floats I checked that. There was a lot of sediment in the float bowl.
not easy to see what’s going on in the tank. I just had the bike apart to replace one of the heads. So I had it pretty well stripped down. Never had a problem with the carb before this.
kwkid66
Sep 25, 2013 08:49 AM
machinehed
EVO
Oct 12, 2012 07:44 PM
Thunderbird1
Jun 6, 2012 07:06 PM
ardvark
Shovelhead
May 24, 2008 12:40 PM
Landfill_Tim
Exhaust System Topics
Jun 7, 2007 09:04 PM
