Tuned?
Old Nov 21, 2019 | 07:20 PM
ktp1598's Avatar
ktp1598
Default Tuned?
So I bought a set of screamin' eagles to replace the V&H straight shots and I think I may have the SE air cleaner. At least the filter part # looks to be the same. When I brought it home a few weeks ago (with the V&H and SE filter) it lightly bucked and surged at low speed steady cruising and the plugs look kind of white. How can I tell if it's been tuned? Where would a piggyback be? The pipes look like they've gotten hot. It's a 2011 Sportster 1200 Custom. So currently I have this air filter/cleaner and a new set of SE slip-ons. Replaced the plugs with NGK's. I just want the low speed surge gone and a nice tan color to the plugs.
Old Nov 21, 2019 | 07:24 PM
ktp1598's Avatar
ktp1598
And the pipes
Old Nov 21, 2019 | 07:27 PM
Iceman24's Avatar
Iceman24
Piggyback tuners are usually under the seat, but you can also check O2 sensors to see if they're routed different than stock. As far as slip-on pipes, filter & plugs, just have the dealer flash your ECM and it should take care of the surge.
Old Nov 21, 2019 | 08:03 PM
ktp1598's Avatar
ktp1598
Iceman24, do the plugs look lean to you? There's no Xied on the O2's.
Old Nov 21, 2019 | 08:06 PM
Iceman24's Avatar
Iceman24
Color of plugs isn't much of an indicator nowadays & blued pipes are norm as well. If bike's running fine & not too hot, you're good.
Old Nov 21, 2019 | 08:09 PM
ktp1598's Avatar
ktp1598
Ok thanks. I was thinking of using a set of Xied's if you think they'll stop the surging. Otherwise it's hibernating for now and I may get a tuner towards spring. I'm thinking the original owner got the V&H's and air cleaner installed when he got the bike. I would think the dealer flashed it.
Old Nov 21, 2019 | 08:43 PM
whylee's Avatar
whylee
Color of the plugs is a good indicator, looking at your plugs and the blue color on the pipes I can tell you its lean. Buy a tuner or have the dealer take care of it.
Old Nov 21, 2019 | 09:16 PM
ktp1598's Avatar
ktp1598
Honestly as much as I like the idea of stage 1 I might just go on fleabay and get a stock back plate and filter, at least for now. (Anybody have a nice one? Don't need the cover) Stock is still a fun ride and way cheaper than a tune. I had thought I was going to leave it alone but I've already spent a small fortune on it!
Old Nov 23, 2019 | 12:25 AM
handirifle's Avatar
handirifle
Instead of Xieds look atvthe ViEDs. Same company, but the V version is adjustable. It does make a difference. Play with the adjustment enough and you can smooth out most of those coughing spells. Works well for me.
Old Nov 23, 2019 | 01:02 AM
springers4ever's Avatar
springers4ever
Cool Good way to test ...
as a test ...used some duct tape and start with covering up about a 1/4 of the air filter ...and take it for ride ...then add a little more to about haft the filter ...retest ...
checking the plugs with each test ...until the lean surge is gone ...should tape and mark the throttle grip 0-25-50-75-100 ...this will give you an idle where the surging is happening
good luck ...
