Tach help!
Old Feb 14, 2020 | 05:49 PM
RacingHugger's Avatar
RacingHugger
Stage II
Default Tach help!
Hello, new to the forum. I'm looking to get a tachometer for my 2003 sportster 883. Anyone know how to do it and where I could find a tach that would fit my bike?
Old Feb 14, 2020 | 06:29 PM
halfmt1's Avatar
halfmt1
Alot of motorcycle parts houses on ebay. I would try there.
Old Feb 14, 2020 | 06:45 PM
RacingHugger
Stage II
Yeah, found several. Thing is, how to i connect it to the bike and make it work?
Old Feb 15, 2020 | 08:22 AM
Racepres's Avatar
Racepres
It is as simple as attaching trigger input to tach to the Trigger side of the coil...
Then generally the white wire is the 12v side of the coil [ignition on] and can be used to power the 12v to tach as well
So it all revolves around the coil!!!
Check your Wiring Diagram to ensure you are attaching the triggers to Trigger side of Coil...all set!!!
Note; I believe that Fuel Injected Models are Single Fire, and therefor require a different Tach... Ensure you get the Correct Tach for your Model... which I believe is Dual Fire... But I am Not familiar with anything very new!!!!
Darn... I think I found a Wiring diagram for your 2003... shows dual Plugs...and seems to be Single fire.. Shop accordingly if this is yours!!!!
Old Feb 15, 2020 | 11:16 AM
Midpegs's Avatar
Midpegs
Not necessarily , S models have dual plugs .
Old Feb 15, 2020 | 05:33 PM
14GuineaPig's Avatar
14GuineaPig
Take a look at these instructions for this Tach Kit
https://serviceinfo.harley-davidson....ght%3D2003+883
harley6277
Mar 2, 2012 12:16 PM
trailey97
Nov 11, 2009 02:54 PM
bertmccarrthy
Nov 12, 2007 02:06 PM
nick03custom
Mar 20, 2007 12:39 PM
twowheelsforever
General Topics/Tech Tips
Jul 7, 2006 02:57 PM
