Recommended Cruising RPM
Old Feb 27, 2020 | 02:07 PM
grbrown's Avatar
grbrown
Wink
Originally Posted by WolvenScout
I know the owners manual for my 2015 Iron 883 states at which MPH I should shift gears at. But what RPM is best to cruise at? On the roads I ride, 45-50MPH puts me at 2800-3K RPM in fourth gear. 50MPH in 5th puts me at iirc 2K PRM.
Those shift rpms are a bare minimum IMHO. Your bike has a red line, so ride it up to that on occasions, to get a better feel for your engine. In the right conditions you can safely cruise at up to 5k rpm IMHO. The more often you use the higher revs, the faster your bike will get.
Old Feb 27, 2020 | 02:19 PM
Midpegs's Avatar
Midpegs
That's more like it ! Two very good pieces of advice . Rev that bike , it's a Sporty not a Big Twin .
Old Feb 27, 2020 | 02:22 PM
Pugslycat01's Avatar
Pugslycat01
As with many things in life, that depends. That's what listening to the bike tells you. Harleys should never whine like a crotch rocket, but the Evolution motor is happier at higher RPMs than are the big twins. If it really is whining you can upshift. If it's bouncing off the rev limiter, you need to upshift. If it lugs on hills or doesn't have the power to pass you can downshift. If you are constantly downshifting, consider staying in the lower gear. What gear you need for which road speed is going to vary with terrain, traffic, and mods you have made to the bike.
The manuals recommended "bogus shift points" are based upon getting the best fuel economy by always riding in the highest gear at which it does not struggle or lug, presumably on a dry, straight, level road. Things are different in the real world and you need to adjust the shift points accordingly.
On the way to work in the morning I have a stretch of 25mph road. The manual says that's the speed to shift into third, but the bike would struggle at that point so I started leaving it in second and accepting higher revs than I liked, but the bike was fine with it. Then I did the stage one upgrades, and it suddenly had plenty of power and torque to ride that stretch in third gear. It was just a matter of doing what made the bike happy.
Old Feb 27, 2020 | 02:25 PM
RKZen's Avatar
RKZen
Like others have said, take it out and do some highway speeds and listen/feel what your bike is telling you. My '11 Custom is very happy and runs the smoothest at 70-75 MPH, about 3200 - 3500 RPM. So that's the bikes sweet spot.
Old Feb 27, 2020 | 04:02 PM
grbrown's Avatar
grbrown
Thumbs up
I had a couple of BMW R100RS bikes way back - according to the owners manual, max speed was 124mph, max cruising speed was 124mph (around 7,000rpm)! They certainly flew and I covered many miles at around 115mph - in Germany, of course!
Much more recently I visited my favourite Harley dealer and while there happened to be close by when a woman arrived on her Sporty, followed in by her 'mate' on his RK. He got off his bike and told her off a strip for changing down a gear to overtake a car - Harley riders shouldn't do such a thing! Pratt.
You're quite right, rev the darned engine, but we big twin owners should do that too - these things aren't V-8s....
Old Feb 27, 2020 | 05:15 PM
apache snow's Avatar
apache snow
I have my red line set at 7400 rpm and I hit it often with no issues but I have a hot rod as well. My valve springs are good to 8000 rpm.
Old Feb 27, 2020 | 07:09 PM
hdbob2006's Avatar
hdbob2006
Put some black tape over the tach,and don't worry about rpms.
Old Feb 27, 2020 | 07:56 PM
gerald martin's Avatar
gerald martin
I think the question was what are the best RPMs to run your sportster at. Example what should the rpm be at 60 mph at 70 mph, at 75 mph ext
Old Feb 28, 2020 | 02:19 AM
Midpegs's Avatar
Midpegs
But there is no choice in the matter only the decision of what gear to be in . If you are doing 60 in 5th gear the revs are what they happen to be . If you increase the revs you go faster and if you decrease them you go slower . This thread is starting to get silly . As previously mentioned , just ride the thing . Look where you're going , hum a little tune and enjoy yourself !
Old Feb 28, 2020 | 02:21 AM
Midpegs's Avatar
Midpegs
Which is exactly what I said at the start of this thread .
