which spark plug
Old Feb 29, 2020 | 08:43 AM
gerald martin's Avatar
gerald martin
Default which spark plug
Hi
I have a 2015 sportster 883 low. It has had the S&S 1200 conversion kit installed, Screaming Eagle 551 cams, V&H short shots with super quiet baffles, screaming Eagle high performance air cleaner and a direct link tuner. my question is what spark plugs should I use, the stock plugs or which suggestions please
Thanks
Old Feb 29, 2020 | 08:49 AM
apache snow's Avatar
apache snow
I use NGK DCPR8E in my hot rod Harley. That's one step colder than the stock plug but I have 10.5 to 1 compression.
Old Feb 29, 2020 | 11:58 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
What does S&S recommend?
Curiously I fitted NGK DCPR7E plugs in a standard 2008 Custom 1200 and the indy I went to recommended I put the HD 6R12 plugs in as he has had failures with NGK but none with HD.
Old Feb 29, 2020 | 12:04 PM
apache snow
I haven't had a failure with NGK in over 40 years in bikes and cars. That's my experience. Hammer recommends you start with 9s, then go to 8s if the 9s are too cold.
Old Feb 29, 2020 | 12:55 PM
Andy from Sandy
That's why I used the word Curiously but the OP has S&S so it would be interesting to hear what those guys recommend.
Old Feb 29, 2020 | 04:41 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
Use the Goldie Lock ones, not too hot and not too cold, just right.
Way too many factors for each mod and how you ride. May have to do some medium and high speed runs but with todays fuels it`s very hard to get a plug reading. Go on the cold side and if you are fouling go up a heat range
Tim
Dec 23, 2015 01:56 AM
bluedeuce4
Jun 28, 2012 11:59 PM
DSG
14
Apr 6, 2012 05:46 PM
Nhgader
Jul 18, 2011 09:54 AM
rgonzaleza
May 19, 2008 09:54 PM
