15 883 iron bars
Old Mar 29, 2020 | 07:35 AM
Brandon Gates's Avatar
Brandon Gates
4th Gear
Default 15 883 iron bars
Looking at putting 12 inch bars on my 2015 xl883n. Will I need to replace the cables and electrical wires or are they long enough to accommodate 12 inch bars? Thanks for the help.
Old Mar 29, 2020 | 08:44 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Hold the new bars against the old. If the height or reach difference is 4 or more inches then almost certainly you are going to need longer cables, brake line and wiring harness to hand controls.
Old Mar 29, 2020 | 09:14 AM
shanneba's Avatar
shanneba
You can download the HD Handlebar installation guide here:
https://serviceinfo.harley-davidson....f-ba2ad59dbe20
For the HD Mini Ape part number 55801003, which are only a 8.75" rise, installed on a 2015 XL883N it shows 10" switch extensions and 6 inch turn signal extensions as needed.
You would likely need even longer extensions.
They show as long as 18" extensions for 2014+ Sportsters on page 200 of the guide.
There are also part number listings for throttle and clutch cables and brake lines.
Old Mar 31, 2020 | 11:09 AM
TUCCI's Avatar
TUCCI
Ah dont go by whatever you've find outlined by someone else. If your adding a 12" ape, add 12" to the existing cable. If its 10" ....well you get the idea. You can go maybe 3" from the originals but that's it.
Quik
Mar 14, 2025 06:52 PM
vaughn4380
Dec 18, 2021 11:21 AM
Issysportster
Aug 8, 2019 07:31 PM
brudford
May 9, 2018 06:35 PM
Mark883N
Jan 28, 2016 10:41 PM
