Cdi
Old Apr 21, 2020 | 04:39 AM
matt_m_72's Avatar
matt_m_72
Default Cdi
So the guy that I had doing the custom wiring on my 92 1200 told me that the low end of the CDI ignition module was going out, it is running rich at idle but runs great on the high end. Has anyone ever had this happen?
Old Apr 21, 2020 | 09:42 AM
John Harper's Avatar
John Harper
No, I have a 1991 and have no issues over 29 years plus. Are you sure it's not a carb tuning issue? That's where I'd look first.
John
Old Apr 21, 2020 | 08:12 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Time to walk away from that "guy." CDI is Capacitive Discharge Ignition and that ignition system is for Metric Cruisers. CDI units will fail at times, but the "lower end of the CDI modual" is PURE BULLSHIT. Do what Harper suggest, carb tuning.
Old Apr 22, 2020 | 11:59 AM
matt_m_72's Avatar
matt_m_72
So I got some more info about the problem, it will run until it get warm then it is running like crap and wont stay running.
Old Apr 22, 2020 | 02:28 PM
John Harper
That could be an ignition module, although I don't think your year has the "nosecone" module that is prone to heat failures. You just have a timing cup in the nosecone and your module is under the small triangle cover just aft of the battery. I could be wrong about what year the "nosecone" module was implemented, but I think it was after 1992.
John
Graybiscuits
General Topics/Tech Tips
Apr 13, 2020 12:15 PM
ScreamingMetalDeathTrap
Mar 2, 2019 08:37 AM
HD1200CVegas
Aug 28, 2017 06:45 AM
Paul Hutchins
Sep 9, 2013 11:17 AM
Kwalk3
Aug 3, 2013 09:09 AM
