Got a clank
Old May 3, 2020 | 04:47 PM
recondoggy's Avatar
recondoggy
Default Got a clank
Was riding, started backfiring and bogging, as I pulled over got a loud clanking, front plug was almost completely collapsed... any ideas? Someone said either a rod or a pin... any suggestions....
Old May 3, 2020 | 05:10 PM
Jackie Paper's Avatar
Jackie Paper
You think the plug had physical contact with piston?
Post a picture. Add a signature line on year model and all letters.
Some detail on bike maintence , miles and modifications.
Old May 3, 2020 | 05:12 PM
recondoggy's Avatar
recondoggy
possibly, I was thinking that...
Old May 3, 2020 | 06:14 PM
Jackie Paper
I think you need to replace the plugs and see what it does. If that ill set plug had started missing, it would have created your run problem and that in it self will rattle a roller bearing motor.
Old May 4, 2020 | 10:02 AM
recondoggy's Avatar
recondoggy
I replaced the plugs a week ago when the same thing happened. This time I got the clanking...
Old May 4, 2020 | 01:18 PM
HOTLAP's Avatar
HOTLAP
I'd do a compression test, the only way the piston would hit the plug is if it's the wrong plug and too long or the piston has divorced the connecting rod and is doing it's own thing in there, much more likely that a valve has dropped or a nut/bolt from the air cleaner has found it's way into the combustion chamber.
Old May 4, 2020 | 02:43 PM
handirifle's Avatar
handirifle
I would pull the plugs and get a bore scope and look inside before restarting that engine. Nothing should clank, or knock a spark plug closed. I have had cars (71 Triumph TR6) that actually split a piston. The split was across the top and went down to the oil ring. When cranking the engine, with plug removed, and using a flashlight, you could see part of the piston, would go down a fraction of a second later than the rest.
When I pulled the piston, the compression rings were all that was holding it together. Had I kept driving when I heard the noise it made, no doubt would have lost the entire engine. I had just put new rings and had head repair done on that engine too. Only did a visual on pistons. Magnaflux would prob have shown the flaw, but that was money I fid not have back then.
Old May 4, 2020 | 02:57 PM
recondoggy's Avatar
recondoggy
Did the test, front plug which is the problem is at almost 130 and rear plug is about 135...
Old May 4, 2020 | 02:58 PM
recondoggy's Avatar
recondoggy
Ok, I'll try that thanks.
Old May 4, 2020 | 03:03 PM
HOTLAP's Avatar
HOTLAP
Then as Handrifle suggested a bore scope would be the next step to actually see what is going on in there, 130 PSI would indicate that the piston and valves are in place but something must be causing the plug damage. Did you open up the air cleaner to see if there are any fasteners missing?
