Baffles drilled wrong
Old May 12, 2020 | 11:18 PM
FORTITUDO's Avatar
FORTITUDO
Stage IV
Default Baffles drilled wrong
Hi I own Sportster 48 from 2011, the bike is complete stock. I got smart and decide to drill a hole on each pipe at the end of the cover of the baffles the issue is when I open those holes one was not in the center. Is this bad for my motorcycle?
Old May 12, 2020 | 11:25 PM
FORTITUDO's Avatar
FORTITUDO
Stage IV
Old May 13, 2020 | 12:50 AM
Pianoman18's Avatar
Pianoman18
Nah. I didn't get mine perfectly centered either. But then again, I only had those plugs for another month before I ordered Cobras! I hope you took them off though to get all the shavings out.
Old May 13, 2020 | 02:20 AM
Midpegs's Avatar
Midpegs
I wouldn't have thought one little hole would make the slightest difference at all to your motorcycle .
Old May 13, 2020 | 02:51 AM
FORTITUDO's Avatar
FORTITUDO
Stage IV
Actually it makes a difference, performance on hight rpms and noise in the low rpms
Old May 13, 2020 | 05:20 AM
Midpegs's Avatar
Midpegs
Well I'll take your word for it . But it still remains difficult for me to understand how a hole the size of a pencil can influence the exhaust note , or the performance of the motorcycle .
Old May 13, 2020 | 06:21 AM
Kenny94945's Avatar
Kenny94945
If the off center variance of your drilled hole is your question....no, it is not bad for the motorcycle.
If drilling a hole to increase the exhaust volume or performance is your question...better experienced forums co-members than I may comment.
Old May 13, 2020 | 09:53 AM
Pianoman18's Avatar
Pianoman18
Oh, it makes a HUGE difference! Got me so excited I wanted louder!
Here's an example of change in tone:
Old May 13, 2020 | 12:05 PM
Madnss's Avatar
Madnss
It’ll probably blow up From all the extra horsepower it’s making now....
Old May 13, 2020 | 12:26 PM
pococj's Avatar
pococj
That little hole doesn't matter. Better to get a hole saw that fits in there and drill out that "hole" area. Makes a 1200 sound very similar to the old XR750 flat trackers. Even the older narrow band O2 sensors will compensate enough that you won't go leaner than it already is.
