Fork tubes 2 inch longer
Old Oct 13, 2020 | 11:34 AM
Mato Pendic's Avatar
Mato Pendic
Default Fork tubes 2 inch longer
Anybody with Sportster 2 inch longer fork tubes pics?.
can i have oem kikstand with it. I have iron 883 with 12.5inch rear.
Old Oct 13, 2020 | 10:57 PM
whylee's Avatar
whylee
If you are just wanting more suspension travel, just buy the Tracker Die longer damper tube kit.
Old Oct 14, 2020 | 08:57 AM
dotcom2000's Avatar
dotcom2000
I went 3" over with 1" lowering blocks on rear. I added a 1 " kickstand extender and all works good. Hope this helps.
Old Oct 14, 2020 | 09:05 AM
templeofdank's Avatar
templeofdank
https://i.imgur.com/5SNyjMS.jpg
https://i.imgur.com/pdMSZXf.jpg
I'm running +2 over tubes with a 4" preload spacer in those pics, in total forks are 2.75" longer than stock. I kept the stock kickstand, no issues. I think if you went +4 or +6 over on the front you'd def want a longer kickstand.
+2 over barely effects riding quality in any noticeable way. It does feel slightly more stable at cruising/highway speeds, and trails better in a straight line. Turning and maneuverability is just as fine as stock, I live in a pretty big city and have no issue getting around and lane splitting. I've ridden a buddy's bike who is running +4 over, same thing there, barely effects ride quality.
Old Oct 14, 2020 | 10:24 AM
WKNDS's Avatar
WKNDS
I believe fork tube extentions like these might be cheaper than new tubes
https://www.denniskirk.com/cycle-vis...prd/585971.sku
Supposedly, only going 2" is 'ok'....
But I agree with the recommendation above to use the longer damper tubes & get the benefit of more suspension travel....
good luck,
T.
Old Oct 14, 2020 | 11:12 AM
templeofdank
good luck,
T.
You wouldn't need longer damper tubes if PVC spacers are used. PVC spacers are the standard option with these fork extension kits, like the ones TC Bros sells. Basically it's a schedule 80 (very dense/hard) piece of PVC tube placed inside the fork tubes at the top between the springs and the fork caps. It preserves stock suspension travel providing the spacer is the same length as the tube extension, i/e: 2" spacer with +2" tubes preserves stock travel.
Old Oct 14, 2020 | 12:54 PM
mrhammer2u's Avatar
mrhammer2u
What's everyone's thoughts on the safety of these longer damper set ups? I've been considering the tracker die as well. I'm concerned there may be some structural loss by extending the forks tubes further out than they are meant to be. I'd prob go +3 as I went +3 taller rears. I replaced the steel fender with a fiberglass shorty but run a superbrace.
Old Oct 14, 2020 | 01:16 PM
lewk's Avatar
lewk
Originally Posted by mrhammer2u
... on the safety of these longer damper set ups? ...
You mean just longer damper rods, keeping all else equal? That's exactly how the MoCo achieves different frontend heights among different models. For example the frontend of my 2007 XL1200L sits lower because it has shorter damper rods compared to the 2007 XL1200R.
Old Oct 14, 2020 | 05:10 PM
mrhammer2u's Avatar
mrhammer2u
But do the different models have different length fork tubes? For example I have a nightster which sits low. Something like a roadster sits a few inches higher. I just assumed the different models had different length forks?
Old Oct 14, 2020 | 06:14 PM
lewk's Avatar
lewk
No. the externals are the same. I have a Low, which sits lower than a nightster. Then I replaced the damper rods with the ones that come stock on the Roadster and whammo... my
Low is now tall like a Roadster.
