Gas Question
Old Oct 20, 2020 | 08:55 AM
flahiker49's Avatar
flahiker49
6th Gear
Default Gas Question
Hello,
I have a 2016 XL1200T and have been using Shell Nitro 93 octane. I can get ethanol free gas but it only 90 octane.
Would that be okay to use vs the 93? Compression ratio is 10:1
Old Oct 20, 2020 | 09:35 AM
chopper_man's Avatar
chopper_man
What does your owners manual recomend for a minimum octane? Mine is 91 for my SGS. That being said, I would certainly try non-ethenol 90 in mine if we had it readily availble near me.
Old Oct 20, 2020 | 09:49 AM
flahiker49's Avatar
flahiker49
6th Gear
It says 91 hard to believe 1 octane would make a difference, but who knows.
Old Oct 20, 2020 | 10:24 AM
mrhammer2u's Avatar
mrhammer2u
Your Sporty manual should recommend 91. That's what my 2012 manual reads. I've been using 87 for years. I have no knocking sounds and no excessive heat. I'm happy to spend that difference elsewhere.
From Car and Driver...
"If you buy fuel with an octane rating above the manufacturer's requirement, you're likely to feel it in your wallet more than the seat of your pants."
There have been vehicles (not high performance) that actually performed worse using higher octane. The Sporty is NOT a high performance vehicle. The Sporty 1200 has about 70hp where the Indian 1200's pump out 100-125hp (depending on model). But now I'm just going to get myself worked up...lol
Old Oct 20, 2020 | 11:42 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How much price difference is there between these two fuels?
All the components in your fuel system are designed to be compatible with 10% ethanol fuel, it won`t hurt anything.
Ethanol has been a reality for at least 20 years, stop worrying about it.
Old Oct 20, 2020 | 11:46 AM
flahiker49's Avatar
flahiker49
6th Gear
Not much the Shell is 2.74 and the ethanol free is 2.81
Old Oct 20, 2020 | 11:51 AM
Dan89FLSTC's Avatar
Dan89FLSTC
At that price I would try the non ethanol...
In my area the non ethanol is much more expensive, and low octane...
Old Oct 21, 2020 | 06:47 AM
Thumper26's Avatar
Thumper26
I agree. If I could get it in New Jersey, I would certainly try it, and always use it if it worked out. As it is here, I can only get non-ethanol gas in aviation grade at local airports, and it is too expensive for continual use except I do use it for winterization with Stabil.
Old Oct 21, 2020 | 07:13 AM
boomerguy's Avatar
boomerguy
All the components are fine with ethanol. However, I run only non-ethanol in colder months when I don't know how long my bike will sit between rides. The rest of the year, when I ride regularly it depends which gas is more convenient to buy. With the number of miles I ride and getting 50 mpg, the price is not a factor.
Old Oct 21, 2020 | 07:24 AM
CoolBreeze3646's Avatar
CoolBreeze3646
You will probably get a little more MPG with non-ethanol as it produces more power than the ethanol version. That said it will only be 1-3 extra mpg depending on how you twist the throttle/
