Baffold?
Old Nov 5, 2005 | 04:52 AM
MikeyBad's Avatar
MikeyBad
Default Baffold?
Talked to a guy tonight who had a 2005 883C with some drag pipes. The bike was very loud. He mentioned that when he put on the pipes, the bike had some performance problems (as expected - drag pipes help out the top end and kill the low/mid range).
He then went on to say that he put in some cones - they fit in the exhaust manifold - right next to the heads. He had to disconnect the pipes from his machine and put the cones in. Once reassmbled - the bike ran as it should.
Anyone know what he was talking about - how much they are - and where they can be found?
Old Nov 5, 2005 | 12:12 PM
WarriorHD's Avatar
WarriorHD
Default RE: Baffold?
I've seen these cones in the J&P Cycles catalog in the exhaust section. You might want to start there. I believe you would have to use the correct cones for your application and it depends on the drag pipes you have.
Old Nov 5, 2005 | 06:31 PM
pococj's Avatar
pococj
They're called torque cones.
Check here:
https://www.hdforums.com/m_79533/tm.htm
MoonCricket
Samson Exhaust
Sep 24, 2010 12:49 PM
elky72ss454
Screamin Eagle CVO Models
Aug 24, 2008 07:30 PM
globero
EVO
Nov 25, 2006 08:47 AM
raven28690
Exhaust System Topics
May 18, 2006 01:22 PM
kata
Jun 19, 2005 09:05 PM
