Braking Is a problem ??
Old Dec 7, 2020 | 01:10 PM
Long lonesome highwayman's Avatar
I've not had a problem with braking on my 98 Sportster yet. If someone in a cross lane suddenly pulls out just 20 feet in front of you while you are going 55mph because they "didn't see you" as happened to a deceased local motorcyclist in my area this year, then good luck stopping in time with anything. I think his bike had ABS, it didn't help him.
Old Dec 7, 2020 | 01:23 PM
boomerguy's Avatar
boomerguy
When I was a kid, there was an empty horse pasture that I used for experimenting with my bikes over the years, spinning out, fishtailing, circular and figure-eight figures while spinning/skidding the tires. This is where I learned to balance the weight distribution front-to-rear with control of front and rear brakes.
The most serious accident that I've had (so far) was during a solitary ride on a very familiar road. Because it was so familiar, I let my guard down in a tight left hand turn and didn't anticipate the gravel "snake" crossing the road in the tightest spot which had washed across during a severe rain storm the night before. The front tire had traction but the rear had lost it, but I still had control. Then I suddenly ran out of gravel which had the texture of beach sand, causing the rear tire to stop sliding immediately, flipping the bike over onto its right side and sending me airborne. Being a snow-skier and used to crashing on the snow, I automatically balled up and rolled about 40 yards down the road. Fortunately, no cars were coming from either direction. I had no "road rash" at all on myself or my apparel. The right hand grip punched a big dent in the gas tank and the handlebar was shaped like the number 7. With my ego shattered, I rode slowly home and faced the music from my wife. That was over 20 years ago and I still hear about it when I get ready to go for a ride. The fact that it happened on Mother's Day didn't help the situation, either.
Old Dec 7, 2020 | 01:41 PM
Midpegs's Avatar
Midpegs
Originally Posted by boomerguy
I didn't mean to give the impression that I don't use the front brake at all. I always use both brakes at the same time. I just use less pressure on the front brake lever than I do on the rear brake pedal. There is ALWAYS pressure from my two fingers, just less of it. I use my front brake for supplemental braking and I have had to use maximum pressure on it more than once but fortunately, not that often. When my foot is on the pedal, my fingers are on the lever just in case.
If you were to re take basic motorcycle training ( in the UK anyway ) you would be taught the exact opposite to what you are doing .
Old Dec 7, 2020 | 02:09 PM
apache snow's Avatar
apache snow
Been riding since 1958. Never had a wreck. never had ABS. Ill keep doing what I'm doing.
Old Dec 7, 2020 | 02:15 PM
boomerguy's Avatar
boomerguy
Considering that I've been riding the same way since 1964 and I've only had the one wreck (so far - don't want to jinx myself), I must be doing something right. So, in the UK they teach you to add more power to the front? And in a turn? Hmmm.....
Old Dec 7, 2020 | 02:27 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Originally Posted by Adsun
it's my 1 Harley and it doesn't have an ABS braking system and I've heard people say it's a little dangerous to drive
All motorcycles are dangerous to drive. You have to be aware of your surroundings, that other vehicles do not see you, and be ready for that vehicle coming the other way to turn left into you. With that said:
Practice, practice, practice your braking skills and your avoidance skills, not necessary the same thing.
Get yourself to a empty parking lot and practice stopping using the rear brake only about 20 times.
Then practice stopping using your front brake only 20 times.
Then practice stopping using both front and rear brakes 20 times.
Then do it alll over again and increase your speed and braking. Once you get a feel of how your motorcycle handles while braking, practice a couple times a week until you are comfortable with your skill set.
Always look forward and out as far as you can while braking and keep your head up and not look down or sideways, it may save you someday.
Oh and if you have not already taken a rider course - schedule one, it will be the best thing you can do.
Old Dec 7, 2020 | 02:46 PM
Jackie Paper's Avatar
Jackie Paper
Pretty sure what I do. However
In slow 180 turns , I drag rear a little. No front. Clutch in or least slipping with a tic of rpm. Seems to add control and pivot around rear. My bike steers slow and heavy. Neck bearings are at minimum fall away. That actually makes it go straighter at speed. Too tight and you oversteer in windy conditions.
Old Dec 7, 2020 | 03:16 PM
Iron Horse 13's Avatar
Iron Horse 13
Using good judgement is where its at lol.
Old Dec 7, 2020 | 03:33 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If you are riding correctly you will have done your braking and gear selection before entering the turn. If you find yourself needing to brake in a turn you didn't read the road correctly. That is you only go as fast as you can see the road ahead. That is what they teach you in the UK.
Old Dec 7, 2020 | 03:55 PM
kero's Avatar
kero
tourings brembos on my 2006
