Changing neck bearings
I have removed hundreds of bearings in jet engines, heating the bearing is a waste of time, because you can`t heat the bearing much faster than you heat the stem, they just grow together and stay tight.
Best way is pay a competent shop to remove it.
Quick way to install, wrap the stem in paper, and cover with dry ice.
Heat the bearing to about 275F with a heat gun.
Drop the bearing onto the stem, turn on the heat gun and keep the bearing warm so it does not get cold and let water condense on it.
Not everyone can do every job on their motorcycle, some jobs are best farmed out to a shop..
You can damage a steering stem pretty quick if you don`t have the right tools to get the bearing off.
This dealership has been in the same location since 1917 and under the current ownership since the 1980's. They have survived this long and outlasted many other motorcycle dealerships for a reason. I got more than what I paid for.
When I called the next day, they said they still did not know what was wrong and that new parts were ordered. A few days later, they said the new parts did not work and more parts were ordered. This continued for 8 days. On the 9th day, they called and said it was ready and that it had been tested ridden for many miles under all braking conditions and it was working perfectly. When I arrived, I test rode it and it was indeed perfect. When I asked what the root cause was, they said they still did not know, that they just kept replacing parts until it worked. I appreciated their honesty. They gave me the 3-page receipt with all the details and all the charges for parts and labor on the last 2 pages had $0.00 beside them. I'm guessing they ate about $2000 to make this right. Everything regarding the rear brakes was new with OEM parts.
When I got home, I put the bike on a stationary jack so that I could rotate the rear wheel by hand to see if anything was too tight, too loose, out of alignment, etc. All was perfect. I called them to confirm this and I have since been back to the shop to talk to them and they said my bike was the first and only bike to have ever done this. This dealership has been under the same ownership since the 1980's and it has a very loyal customer base, so that is saying something. They treated my old bike like it was a brand new top-of-the-line bike. The other motorcycle dealerships which sell metric and euro bikes have terrible reputations regarding customer service.
I can't think of anything more scary than failed brakes.
Sounds like a real nice place to do business with though.
The day I picked it up, the service manager was out riding it one last time, putting the bike through several very hard stops to try and make it fail. They were very patient with all my questions and I was patent with them. It literally paid off. I am very glad that I didn't get a shade tree mechanic work on it with aftermarket parts. I have nothing against aftermarket parts on some things but safety is a priority for me.
Repairing the piston on the front brake was never a problem. The repair was instantly successful but the rear brake was a completely different issue. I've put about 8K miles on the bike since then and all is well.
and rear brakes on early rubbermounts are known trouble makers. my 08 never failed me to this day tough *knock on wood*
Both brakes were performing well before I took the bike to them. The only problem was the pistons not retracting when I needed more room for a new pad. The front pistons repaired easily but the rear one remains a mystery. Anyway, all is good.
