97 Evo Sportster No 5th Gear
Old Feb 23, 2021 | 12:07 PM
David Kirkham's Avatar
David Kirkham
Stage III
Default 97 Evo Sportster No 5th Gear
I have a 1997 Sportster that will not go into 5th gear. I picked it up about a year ago. It has 21k miles on it and was pretty neglected. Over the year, I have done a ton of work to it, mostly never done maintenance. I just pulled the primary cover and set the shifter pawl. I also replaced the clutch with a Barnett extra clutch plate set and Barnett spring plate. I set the clutch cable and obviously replaced the primary oil. I feel like I have made all the necessary adjustments necessary for the bike to run properly. It did not go into 5th when I got it and it does not go into 5th after all of my repairs. I did not pull the transmission. Thanks.
Old Feb 23, 2021 | 02:23 PM
Midpegs's Avatar
Midpegs
Well at least you can pull the transmission without splitting the cases on a 97 if that's any consolation . It's probably a bent or worn selector fork .
Bdp314
May 19, 2019 06:36 AM
paul read
Apr 30, 2018 05:01 AM
Sportbob769
May 28, 2014 10:01 PM
paulrelayer
Mar 8, 2013 05:39 PM
dirtyenginehugger
Nov 5, 2012 06:38 PM
