Sportster help
Old Feb 27, 2021 | 12:39 PM
Jrayguns's Avatar
Jrayguns
Stage I
Default Sportster help
Good day everyone. Brand new member to the forum and a new harley owner here and im getting my *** whooped. My father gave me his 1990 1200 sportster. The bike sat for 2 years before i recieved it. After i did a full bike fluid change, new plugs and wires, cleaned carb and a full maintenance on thw bike i have one issue. My brake light only works when my lights are off and the taillight doesn't work at all. I put a ne bulb in still nothing. So i purchased a clymer manual and decided to start by checking all my grounds. The first ground i did was under the battery right next to thw brake light switch. I took it off, cleaned the connectore, the bolt and the frame with a wire brush. Put it back together and now i still have no taillight but i also have no headlight. With electrical being my kryptonite i figure i better reach out before i make it worse. Anything you guys recommend i do? I have a couple of kids and a wife so needless to say i rather not put it in the shop lol. Any help would be great. Thank you all for reading
Edit: i got the headlight back on. Error on my end. But still no taillight at all and no brake light when my lights are on
Old Feb 27, 2021 | 04:44 PM
FreedomRider's Avatar
FreedomRider
The HD Factory Service Manual is a better manual and cost a little more, but worth it for the information it contains ... check all fuses, trace wires and check connections ... I think the taillight has connectors under the seat, make sure those are good ... I'm sure someone will be along with better electrical knowledge but what I gave you is a start ... welcome and enjoy the bike
Old Feb 27, 2021 | 05:29 PM
HOTLAP's Avatar
HOTLAP
Also check the wires under the rear fender going to the brake light, sometimes the suspension will bottom out and the wires can get damaged by the tire.
When you say taillight and brake light do and don't work are you checking the power wires just before the taillight or relying on the bulb? a lot of problems start with the wrong bulb jammed into the socket or a corroded socket, I would be checking for power at the wires to eliminate any potential problems with the socket, in fact I would probably start with disconnecting the taillight and just checking wires, if they are working then you can use test leads to check the socket.
Old Feb 28, 2021 | 04:09 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Wiring diagram here - 99948-90_en - Wiring Diagrams - 1986-1990 All Models | Harley-Davidson SIP (harley-davidson.com)
Old Mar 1, 2021 | 08:55 AM
benjamin lorenzo's Avatar
benjamin lorenzo
Post
Get yourself some electrical cleaner contact spray, some small wire brushes ect and some dielectric grease. Either way every time you disconnect a wire connector clean it and grease it with the dielectric grease.
Roadrage1996
Apr 22, 2017 09:13 AM
shwthomas1975
Oct 30, 2013 02:46 PM
Corporate_trash
Jun 3, 2012 08:17 PM
scootertrashpie
Aug 30, 2009 04:13 PM
Bollocks
Oct 8, 2006 07:17 PM
