clutch issues
Old Mar 20, 2021 | 11:37 AM
sidewalkman's Avatar
sidewalkman
Default clutch issues
Hi All
My wife has a new to her 2013 Model 72. The clutch is harder to pull than my 07 Ultra. Is there a way to make the clutch pull easier?
Old Mar 20, 2021 | 01:40 PM
LordSargon's Avatar
LordSargon
Muller motorcycle makes a part for that
I've never tried it, however.
Old Mar 20, 2021 | 05:38 PM
08xl1200r's Avatar
08xl1200r
Make sure the clutch cable is good before buying alternate parts, a gunked up one can make the pull very hard. I'd also check that the adjustment in the primary and the one for cable free play are correct.
Old Mar 21, 2021 | 06:54 AM
boomerguy's Avatar
boomerguy
+1 on all of the above. There are a lot of videos on YouTube for this and pay special attention to the seal at the primary. Two Wheel Rocco has a great video on this. AND, add to the "while you're at it" list, spray the inside of the clutch cable housing with some teflon bicycle chain or cable spray. You can get this stuff at any bicycle shop or online and one small can will last a lifetime. I also use it on doorknobs, locks, pliers, socket wrenches and any other metal moving parts. It's clean, smells good and lasts almost forever.
File this to your memory bank, the bigger the engine, the stronger the clutch diaphragm spring. There is an aftermarket clutch throw-out (release bearing) made in Germany, called the *** 7200B which is far superior than the stock one, plus it is actually designed for its job. This bearing made my clutch lever much smoother and easier to pull. There are videos on this, as well.
Old Mar 21, 2021 | 07:09 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The new cable I bought for a 2008 bike had the inner plastic coated. Using something like 3-in-1 would be liable to gum that up. So as above it might need cleaning out and if you want to use a lubricant then something like triflow could be used.
Tri-Flow Oil With Teflon 2oz TF21010 for sale | eBay
Old Mar 21, 2021 | 07:14 AM
boomerguy's Avatar
boomerguy
Yep, this is what I use. It also comes in an aerosol spray can which makes it much easier to apply the lube. I've been using the stuff for about 20 years on everything where metal makes contact.
bladeguy
May 20, 2021 09:36 PM
southerncannuck
Apr 1, 2019 10:22 AM
cvaria
Apr 21, 2017 12:08 PM
texacon
Jul 18, 2011 07:32 PM
Pippeis
May 27, 2006 12:36 PM
