06 883 won’t idle when hot
Old May 18, 2021 | 08:10 PM
sparky96's Avatar
sparky96
1st Gear
Default 06 883 won’t idle when hot
So my 883 is having trouble idling once it’s gotten good and hot. To start I have to choke it a little bit it fires pretty easy and after a second on choke it will sit and idle fine. Let it warm up and bit then take off. Bout 8-10miles in starts idling like **** and won’t hardly run without me giving it some gas. Once I give it gas it runs fine but won’t idle on its own very well. I wouldn’t think it’s got junk in the carb if it only does it when it gets hot. Any ideas? Has Vance and Hines short shots and everything else is stock. It ran fine for a long time with that exhaust before this issue started.
tried attaching a video but I guess I don’t know how of it won’t let me for some reason
Old May 19, 2021 | 06:29 AM
Gary1's Avatar
Gary1
Check for vacuum leaks by spraying carb cleaner on carb and intake and see if you can get a change in idle which would mean a vacuum leak.
Old May 19, 2021 | 06:33 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If you give it a little choke does it idle? As above indicating an intake leak or weak mixture.
Old May 19, 2021 | 07:42 AM
72 Ironhead XLH's Avatar
72 Ironhead XLH
open the mixture screw a bit
Old May 19, 2021 | 07:52 AM
Andy from Sandy
"It ran fine for a long time" would be a reason not to make adjustments just yet.
Old May 19, 2021 | 10:28 AM
sparky96's Avatar
sparky96
1st Gear
would this be with the air cleaner still on the bike?
Old May 19, 2021 | 02:39 PM
Gary1's Avatar
Gary1
I would remove it so you can spray in all of the nook and crannies.
hexnut
Oct 2, 2014 05:35 PM
proanti1
Feb 8, 2010 06:04 PM
Madgoat
Oct 14, 2006 09:13 AM
kevinjg
Exhaust System Topics
Jul 3, 2006 08:26 PM
npd_66
Apr 19, 2005 09:22 AM
