Starter problem!?
Old May 25, 2021 | 10:13 PM
Jason Haiduc's Avatar
Jason Haiduc
2nd Gear
Default Starter problem!?
I have a 2003 XL 1200S. I went out for a ride and stopped for a bit. When I got back to my bike I went to start it and all I got was click sounds everytime I pushed start. All lights were on working. Couple minutes again after trying it finally started and away I went. What should I be looking at to find the problem?
Old May 25, 2021 | 11:47 PM
Riffraff123's Avatar
Riffraff123
Dead battery
Old May 26, 2021 | 03:25 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
How far did you go and in what time frame before stopping?
I agree the battery seems the most likely candidate but is the charging system working properly and are all the connections clean and tight?
Is this the first time it has happened?
Old May 26, 2021 | 03:59 AM
Midpegs's Avatar
Midpegs
Check those connections first .
Old May 26, 2021 | 04:04 AM
Jackie Paper's Avatar
Jackie Paper
Battery connects are loose is where to start. Then attach a volt/ohm meter. Should be 12.7 DC. 12.3 is dead battery.
All good. If not, charge it with maintenance charger overnight. Remove charger . Hit lights on and off Voltage still good? Now crank watching meter. Should not drop below 9.6. If it does, battery is worn out.
All good and running, rev up to high 2000 rpm idle. Voltage should be around 14.2 but under 15.
Do not jump start a Harley except in an emergency .
Still loud click? Check the contacts in the starter solenoid. They are replaceable. If you replace them, do the little starter relay also. Use OEM Harley parts.
Old May 26, 2021 | 06:41 AM
CoolBreeze3646's Avatar
CoolBreeze3646
How old is the battery?
As above or: Remove the battery and take it to get load tested at an auto parts store.
If is good do these checks:
https://www.hdforums.com/forum/elect...sting-1-a.html
https://www.hdforums.com/forum/elect...sting-2-a.html
tvr
Nov 14, 2016 10:23 AM
JT-FXDL
Sep 29, 2011 02:28 PM
dr.hacknthebush
General Topics/Tech Tips
Sep 10, 2011 08:38 PM
Keith Gleason
Oct 12, 2004 08:44 AM
