Dreaded Broken Exhaust Stud
So since I've decided not to do it myself I guess my next question is where to bring it. Is my best bet some sort of machine shop or bike mechanic at a dealer somewhere? It looks like I can remove that part of the cylinder head while the engine is still in the frame? Or do I need to actually pull the motor to get it off?
Doing some searching around the forums it seems like the general consensus is not to attempt to remove using an extractor and rather to take the cylinder head off and take it to a machine shop to have them remove it. Seems smart. Deep enough in there and I'm an inexperienced enough mechanic that I don't think I want to attempt it myself anyway.
My question is, can I bolt the exhaust on using the remaining stud and still run it for the rest of the season if I'm diligent about checking the nut since they're obviously prone to vibrating off? I'm currently in the process of a top end rebuild on my suzuki engine so this is my sole ride right now. I've only just started riding this season due to title/registration issues, and since it's almost July already the riding days are numbered here in Michigan. I'd hate to have my riding season cut short just as it was getting started and it would be nice if I could wait until the snows come and I'm not riding anymore to get the cylinder head off.
An old school machinist will have it out quick smart. Just remember when you go to the machine shop take a new stud and gasket, youll be riding away fixed!
Never, ever, attempt to extract the broken stud. That's a rookie mistake that lots of people make because they don't know any better. Those factory studs have a special interference fit thread, which means they are designed to bind up in there. And they do a mighty fine job. If you attempt to extract it, as opposed to drilling it out, you are far more likely to make things worse than make them better. The drill guide tools do a fantastic job. They use a 1/4 inch drill bit and it's a 5/16 stud. Generally speaking, using the drill guide you can basically hollow out the stud, leaving a threaded shell that's pretty easy to get out of there. And generally the threads will still be good.
Despite the complications of being unable to extract them, my own personal opinion is that the interference thread studs are a good thing, and whenever I perform this repair, I use a factory stud for that reason. I've yet to find an aftermarket replacement stud that's interference fit thread on one side like the factory piece. Without that interference fit thread, the stud will try to unscrew on you. That area is way too hot to rely on Loctite to hold it in place.
The tool that George's offers is cheap compared to what you'll spend to have it fixed: https://www.georges-garage.com/produ...tud-drill-jig/ . A new factory stud is about 5 bucks at the dealer, part number 16715-83
