Brake Light Issue
Old Sep 8, 2021 | 05:53 PM
dotcom2000's Avatar
dotcom2000
Default Brake Light Issue
The brake light stays on. It's a '06 1200L with no mods to the electrical system. I've replaced the tail light bulb and socket and the brake light switch. I recently replaced the rear master cylinder but I don't see how that would affect anything. Even with the front and rear switches disconnected it stays on. The bike runs great. My FSM disappeared about a year ago during a move and haven't replaced it yet. All the wiring looks great. ? I gotta be missing something , any ideas ? Don't want to tow this sucker to the dealer but I'm at a loss. I would appreciate some guidance here.
Old Sep 9, 2021 | 12:52 AM
72 Ironhead XLH's Avatar
72 Ironhead XLH
Old Sep 9, 2021 | 07:15 AM
davekp's Avatar
davekp
Disconnect the rear switch. If it the light goes out, the switch is defective. If the light stays on, the front brake light switch is defective.
Old Sep 9, 2021 | 07:46 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Read what he wrote! "Even with the front and rear switches disconnected it stays on."
Wiring diagram -
99949-06_en - 2006 Wiring Diagrams (harley-davidson.com)
The only thing that would make sense to me with the switches disconnected is the insulation of the wires is damaged and they are touching together. The switches feed accessory power so not a connection to ground.
How did you disconnect the switch at the handlebars?
Old Sep 9, 2021 | 11:28 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
I had a similar problem a couple of years ago, my brake lights were staying on all the time on my 2011 XL883N, I traced the problem to the front brake light switch actuator being stuck in, the actuator is a plunger type. the switch is located inside the brake reservoir casting.
I removed the rubber dust cover from the switch and I cleaned the plunger with WD-40 and then I lubricated the inside of the dust cover using a small dab of grease, that cured the problem and the switch has worked perfectly ever since.
Old Sep 9, 2021 | 11:32 AM
Andy from Sandy
It is very easy through wrong assembly to knock the top of the switch off and get a problem but the OP states the switches have been disconnected and the light stays on.
Old Sep 9, 2021 | 03:33 PM
dotcom2000's Avatar
dotcom2000
Andy from Sandy got it right. I cut the O/Y to the front switch. I figured it was a short, I just can't find it. Thanks to all for your replies. I will post the fix when I find it.
Old Sep 9, 2021 | 05:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You say the brake light stays on with both brake light switches disconnected, not being a smartass here, but are you sure you are not seeing the tail light?
The tail light will be illuminated with both brake light switches disconnected because it is on a different circuit.
Look at the tail light bulb, are both elements lit up, or just one element?
This is a very simple circuit, let us help you find the problem.
Old Sep 10, 2021 | 11:51 AM
dotcom2000's Avatar
dotcom2000
Its sorta difficult to follow a schematic on a laptop so I drew out the curcuit on a piece of paper. It looks like the brake light has its own fuse (please correct me if I'm wrong ). I guess my next step is to pull the fuse and see if that kills the light or if its powered by a short. If the light goes out I need to go get more beer. If it doesn't go out I need to go get more beer.
Old Sep 10, 2021 | 12:40 PM
Andy from Sandy
The brake light is powered from the ACCESSORIES fuse.
As a test can you put the ignition key to ACC position. Does the brake light come on? If not can you join the rear switch wires together. Does the brake light come on?
