Replaced Oll Lines now Electrical issues
Since an electrical issue, head light, foot break light, left turn and security light stay on when running/ cut out at times bike runs same with lights on or off. i have removed the fender as I assumed i didn't get the rear harness connected tight, checked and cleaned all connections,
all time issue
Brake light works with front brake, only foot break light isn't working.
Head light out,
turn on and off together randomly
security light
left turn signal.
bad security sensor?
09 883C / 1200 conversion Jug & Piston only.,
K&N Air Kit,
Vance & Hines Exhaust 56K
As above start by checking for codes. Explained here - Harley Trouble Codes (fuelmotousa.com)
You might of disturbed a connector or 3. You might of damaged some wires.
I would start by doing a thorough visual. I would give any connectors close by a pull and a wiggle.
09 bike check all fuses and relays are seated properly and show no signs of corrosion.
Check the ground wire is not damaged and the connection is clean and tight that is connected to the right side of the crankcase. Check other end at battery.
Ran codes b1125 left turn fault. i have checked all connectors. confirmed ground at battery and motor are both snug, the ground for the tuner is also secure. Front o2 sensor connector lock is broke but is snug.
