Engine running SAE primary is now running syn 🤦‍♂️🤦‍♂️🤦‍♂️
Old Oct 23, 2021 | 09:04 PM
UrBoySkiJump's Avatar
UrBoySkiJump
6th Gear
Default Engine running SAE primary is now running syn 🤦‍♂️🤦‍♂️🤦‍♂️
Engine is running SAE, primary is now running Syn 🤦‍♂️🤦‍♂️
Subscribed
UrBoySkiJump , Today 01:36 AM
New Member
Hey what's going on guys I'm new here an not sure If in posting in the right place but I changed my oil on my 2021 iron 883 a couple days ago and after watching a few videos realized it ain't **** to change my primary
Its a brand new engine so I was going to switch to synthetic next change and told the guy at the bike shop this and he sold me a quart of Lucas 20-50 for a wet clutch I didn't think anything of it and just put it in not realizing it's synthetic while the engine oil is SAE now I'm scared to start if up
Please help?????!!!!??
Old Oct 24, 2021 | 07:26 PM
John Harper's Avatar
John Harper
There are separate oiling systems on the Sporster. Engine oil, in the oil tank. Primary drive chain, clutch hub assembly, and transmission oiled in the primary chaincase. One quart in the primary chaincase, and ~2.5 quarts in the oil tank. Buy yourself a Factory Service Manual, so you can always check what service procedures are correct for your bike.
No issue using 20/50 synthetic if rated for wet clutches. There are many oils out there to choose from, all likely serviceable for our needs. Mobil 1 75W90 gear oil, Bel Ray STL (my choice), Golden Spectro STL, 20W50 motor oil (not my choice, but HD says okay), even ATF! All seem to be used in the Sportster primary case. Just don't put gear oil in your engine oil tank.
Good luck, and welcome!
John
Old Oct 25, 2021 | 12:27 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Have you covered the first 1000 miles?
What about the engine oil?
What about the servicing of the rest of the bike.
Does your **** youtube videos cover the full list of items that need checking out after the first 1000 miles?
Do yourself a big favour and get a service manual. I have seen several 'tube videos that are not actually suitable for your bike even though they are Sportsters.
Old Oct 25, 2021 | 08:21 PM
Madnss's Avatar
Madnss
Definitely a recipe for disaster. A couple of revs and she’ll blow the heads completely off. Look for a strap to tie over the top of the engine like the top fuel bikes use. You do not want a piston to take out your jugular.
Old Oct 26, 2021 | 08:46 AM
slw210's Avatar
slw210
So you some how managed a non-SAE oil in the primary? They both should be SAE oil, synthetic or conventional. What oil is in the engine?
Now the point that you have Lucas Oil, that's a horse of a different color!
Old Oct 26, 2021 | 08:50 AM
slw210's Avatar
slw210
Originally Posted by John Harper
.......Just don't put gear oil in your engine oil tank......
What would happen?
Old Oct 26, 2021 | 11:19 AM
John Harper
Originally Posted by slw210
What would happen?
The fall of western civilization, most likely.
John
UrBoySkiJump
Welcome Area Only
22
Oct 29, 2021 08:09 AM
kreeess
Oil Archive (no new posts)
Aug 19, 2014 05:55 PM
HighestHD883
Jul 30, 2014 03:35 AM
harleyglen
Sep 29, 2013 09:21 PM
Cmonks91
May 8, 2013 08:32 PM
