Speedo Cluster Indicator Lights
Old Oct 26, 2021 | 06:38 AM
piratemike66's Avatar
piratemike66
Stage IV
Default Speedo Cluster Indicator Lights
Hey Everyone. I have recently purchased a 2005 883, as a project, that had been sitting outside under a tarp for about a year. So far I have made good progress as it now runs and is rideable. My problem is with the speedometer indicator lights.
Several of the rubber lamp holder/sockets have rotted away and now the lamps will not mount to the speedo bracket. I went to the dealership and these items are no longer available. I checked for aftermarket replacements and no luck there either.
I am fine with not having them so, I removed the lamp wiring for those indicators from the harness. Is this going to create any problems with the turn signals etc.? Does anyone know of a source for those plugs or an aftermarket replacement for the whole setup?
Thanks,
Mike
Old Oct 26, 2021 | 09:17 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
This is probably expensive but working on the basis that only parts 10 years old are available from the MoCo...
The parts from a 2011 to support the light cluster and then make a wiring harness to incorporate the new with the old.
Ronnie's Harley-Davidson's 2011 Harley Davidson SPORTSTERŽ XL 883N IRON 883 (LE) | SPEEDOMETER ASSEMBLY Parts List (onlinemicrofiche.com)
New old stock search on ebay?
Removing the indicators completely will mean you lose the oil light. That might be important one day.
Old Oct 26, 2021 | 10:21 AM
Gary1's Avatar
Gary1
Probably on ebay....used though.
Old Oct 27, 2021 | 07:24 AM
WKNDS's Avatar
WKNDS
You might check the V-Twin Mfg catalog, they might have what you need.
Here is an example...
https://www2.vtwinmfg.com/indicator-...hometer-4.html
hth,
T.
LLubers
Electrical/Lighting/Alarm
Sep 23, 2013 10:12 AM
MrNormal
Apr 28, 2013 09:56 PM
nunez8853
Jun 10, 2012 07:47 PM
stonewall308
Dec 24, 2009 04:35 PM
OCBINVA
Jun 29, 2007 12:46 PM
