need help with wiring
Old Aug 10, 2007 | 01:48 AM
wafreelance's Avatar
wafreelance
1st Gear
Default need help with wiring
Ihave a 1991 1200 sportster it had a screaming eagle ignition coil that burned up. I have forgot how to hook the wires up, I have a two bundles of wires, one has a white and blue wire and the other has a set double red wires and set of double white wires. I need to know where these wires go and which cylinder goes to which sparkplug connector, if you look at the coil, connections facing you, I have two wire studds one on left one on right and then the two spark plug connectors, front cylinder vs back, Thank you in advance. wafreelance
Old Aug 10, 2007 | 06:40 PM
olesalt's Avatar
olesalt
Default RE: need help with wiring
http://www.whitehorsepress.com/produ...oducts_id=2164
Mr.Norm31
Jul 16, 2018 09:31 AM
jqb12
Nov 27, 2015 11:59 AM
T-rat
Apr 3, 2013 12:55 PM
Brutus01
Apr 6, 2012 11:55 AM
wafreelance
Aug 10, 2007 07:31 PM
