Torque Specs?????
Old Nov 10, 2005 | 04:17 PM
Tx883c's Avatar
Tx883c
Default Torque Specs?????
OK, I posted about my leaking rocker boxes a few days ago and today I have the gaskets so I'm gonna try to install them tonight. Only problem is my service manual probably won't be here for another week or so but the leak is getting worse so I want to fix it now. Does anyone know what the bolts are supposed to be torqued to???
Old Nov 10, 2005 | 04:36 PM
brohrs's Avatar
brohrs
Default RE: Torque Specs?????
Go down on the forum a page or two its been posted twice.
Old Nov 10, 2005 | 04:43 PM
Tx883c's Avatar
Tx883c
Yeah I found it after I made this post
Thanks!
brohrs's Avatar
brohrs
I found it for you. Go to search and type in rocker box. It will be the post of a man named Levy.
Old Nov 10, 2005 | 04:44 PM
brohrs's Avatar
brohrs
You are welcome.
Old Nov 11, 2005 | 03:25 AM
Tx883c's Avatar
Tx883c
Well, I got the gaskets put on tonite!! It wasn't too bad, I did the rear cylinder first and it wasn't real fun because theres no room to work in there. Then I did the front one and it was easy!! The hardest part of the whole ordeal was scraping the old gaskets off!! If you are leaking oil then this is a must do fix!!!!
HOGILAC
Mar 3, 2016 07:39 PM
heavyd1
Jan 4, 2013 10:26 AM
emperor wurm
Jan 13, 2012 05:47 PM
kegger13
Sep 25, 2009 01:48 PM
cleanandsimple00
Aug 11, 2007 02:23 PM
