Help
Old Apr 25, 2022 | 11:17 AM
Clferg40's Avatar
Clferg40
Stage I
Default Help
I'm having issues with the fuel line leaking on my 95 883XL. It appears to be leaking from between the frame in front of the back tire but I can't tell where. I pulled off the battery bracket and it has a hose that has gas running through it going inside the frame. So my question is, is there somewhere it comes out lower than behind the battery bracket. Am I missing something?
Old Apr 25, 2022 | 01:06 PM
Midpegs's Avatar
Midpegs
Some pictures would be useful . Sounds like the overflow / vent pipe or maybe your Carbon Cannister is flooded .
Old Apr 25, 2022 | 02:59 PM
96hugger's Avatar
96hugger
Turn off petcock and knock the float bowl lightly a couple times, carb float probably stuck or petcock vacuum is bad, if it's coming from carb overflow
hwyfever
Oct 18, 2019 08:04 AM
rotorkarl
Apr 30, 2017 10:25 AM
stephtell
Shovelhead
Sep 21, 2015 06:20 AM
pleasants9
Apr 10, 2012 02:38 PM
Firebike32
Apr 11, 2011 07:34 AM
