Frame welding
Old Apr 8, 2011 | 07:24 AM
Firebike32's Avatar
Firebike32
Default Frame welding
I've got a broken rear fender support bracket broken on our Ultra. Is there any precautions to take in regards to the electrical system when welding on a frame? Thanks for the help.
Old Apr 8, 2011 | 07:41 AM
Old Bones's Avatar
Old Bones
Disconnect the battery.
Old Apr 8, 2011 | 07:44 AM
themickster's Avatar
themickster
Yup agreed, make sure to disconnect the battery and you should be good....
Old Apr 8, 2011 | 08:02 AM
MatSubZero's Avatar
MatSubZero
I had my frame break too because the previous owner had it painted and left out 2 bolts that hold the fender on which put extra stress on that part of the frame. And I used to haul a good size loaded ice chest on my luggage rack. The tire wiped out all my wires when frame broke. A buddy welded it up pretty good but had to cut part of the aluminum fender bracket off to fit over the weld. In regards to you question, I dunno...
Old Apr 8, 2011 | 09:42 AM
fitter235's Avatar
fitter235
6th Gear
Put the ground clamp as close to the weld as possible. Don't put it at the opposite end of the bike.
Old Apr 8, 2011 | 10:12 AM
firefighter616's Avatar
firefighter616
+1 right there and disconnect battery
Old Apr 8, 2011 | 10:39 AM
MrMax's Avatar
MrMax
As others have said previously. Disconnect the battery and keep the ground clamp as close to the working area as you can to minimize how much of the bike the welding current runs through. You can inadvertently "spot" weld/destroy bearings and bushings by running current across them
Old Apr 8, 2011 | 10:47 AM
dickey's Avatar
dickey
Have you got pics? Where & how did the frame break? Never heard of that happening.
Old Apr 11, 2011 | 07:34 AM
Firebike32's Avatar
Firebike32
Sorry no pictures. At the front of the rear fender there are two brackets welded to the frame that the fender bolts goes through. I beleive you can see the brackets if you take the side covers off. This might have been a self inflicted problem. 80K with a trailer might do that. All back together now and ready for the road. Thanks for the help guys.
Matthew Valinsky
Jan 11, 2017 09:12 AM
wenna
May 26, 2014 07:53 AM
Bill Murray
Jan 26, 2014 05:06 AM
AudiFan
Aug 1, 2012 01:10 PM
marlontoruno
Mar 4, 2010 02:19 PM
