Here is the situation, Bought the bike used. has aftermarkey ignition and coil pack relocation kit on it. A friend was riding it and the key fell out of the ignition. The bike sat all night until the headlight killed the battery. I ordered a new ignition switch and replaced the old one with the missing key. Now when you turn the key on the headlights come on, the fuel pump turns on, but when you hit the start button nothing happens.
I tried replacing the starter relay, and the system relay to no avail.
Could the coil packs have gone bad by sitting with the ignition on all night? Does the bike require continuity through the coil packs to even turn over the starter?
There are a few error codes showing in the odometer. The red key keeps showing up on the odometer also.
The ignition coils have nothing to do with the starter not cranking the engine.
any help would be appreciated. Thanks.
did you find out what the issue is? Im having the same problem exactly
No, I am leaning towards an ECM problem. There is just literally no power going from the start button to the starter. Everything else turns on just fine.
