Primary case noise
Old Sep 21, 2022 | 05:23 PM
Stubby01a's Avatar
Stubby01a
Stage II
Default Primary case noise
Weird noise from primary case on dow shift and take off. Have a 07 xl1200l. Thought it was chain adjustment but seems within specs.
Old Sep 21, 2022 | 05:48 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Have you checked the clutch adjustment?
Old Sep 21, 2022 | 05:51 PM
Stubby01a's Avatar
Stubby01a
Stage II
Default Clutch
Seems fine, might need cable though
Old Sep 22, 2022 | 05:19 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Can you be more descriptive?
Is the noise continuous or just some kind of click or clunk as the gear changes?
When the clutch is still pulled or when you let the lever out?
Does the engine appear to rev slightly that would occur if the clutch is slipping?
Has the spring plate been eliminated for an extra plate kit so you are getting a bit of a squeal?
Ron Carlson
Mar 29, 2020 11:32 PM
masterguns
Dec 7, 2016 11:26 AM
JONNIEROCK
Sep 4, 2010 08:32 AM
StreetGlider56
Nov 19, 2009 10:04 PM
MaxShovel
Oct 4, 2008 11:52 PM
