Possible clutch/transmission issue, or just me?
I've adjusted the clutch, adjusted the slack in the primary chain to specs, and even switched from the heavy HD gear oil to Schaeffers V-twin chaincase lube thinking maybe the heavier gear oil was causing the clutch plates to stick together and not fully release.
Around 18,000 miles I swapped in an Alto HD spring plate, and changed over to an NSK 7200BWG thrust bearing for the standard ball bearing HD uses for the thrust bearing. Bike now has 31,600 miles on it. There is no strange noises, bike shifts fine other than the feeling I'm catching gear teeth at times.
Any ideas what could be causing this, or is it just me since it doesn't do it 100% of the time?
It has done it with and without the spring plate and with Formula+ and the HD synthetic gear oil.
