Stripped?
Old Apr 29, 2023 | 06:08 AM
John Ha's Avatar
John Ha
It may be helpful to remove the shock before you start the tap. It's very important to go into the hole straight to correct the threads. Also, since you stripped the first 1/4" of threads, you don't need or want a shorter bolt. If you get the threads sorted you'll be able to thread a bolt of the original length into the undamaged threads deeper in the hole.
Old Apr 30, 2023 | 09:01 AM
McGurk's Avatar
McGurk
FIX MY HOG claims Loctite thread repair WILL work 8 out of 10 times. I'm gonna give it a shot. Doesn't work I'll return it.
Old Apr 30, 2023 | 09:34 AM
McGurk's Avatar
McGurk
I certainly appreciate all the veteran advice whatever way this turns out. I'm hoping like hell the Loctite thread epoxy stuff works. Looks like a JB Weld kinda thing which despite all the trash talk it gets IS amazing. I've got stuff I fixed w/ JB that seemed hopeless.
*edit*
I removed & reinstalled it & it went in OK but got progressively harder quickly. Again I took to about 1/4 in of flush but stopped at 72ft/lbs or damn near 100nM since I read the bolt will break at 135nM. Got a damn good local indy shop scheduled to look at it on the 10th.
Old Apr 30, 2023 | 10:43 AM
John Harper's Avatar
John Harper
JB Weld has always worked great for me too!
John
Old Apr 30, 2023 | 01:40 PM
McGurk's Avatar
McGurk
IN THE RIGHT APPLICATION...JB is good stuff. The old 'hole in the engine block' BS I don't buy. IDK what the tensile is on it but has been tested to 5k PSI which pretty damn good for a $7 tube of glue.
Old Apr 30, 2023 | 01:51 PM
John Harper
I patched a hole in the case of my friend's dirt bike after he threw a chain with JB Weld, worked just fine.
John
Old May 20, 2023 | 02:51 PM
McGurk's Avatar
McGurk
*UPDATE*
I ended up reinstalling it w/ (2) thick washers and it flushed up fine @ 55ft/lbs. Test rode it and no problems whatsoever. Cost ($0).
sledgeb1
Apr 30, 2023 03:01 AM
Buch
Dec 1, 2015 07:36 PM
maverickwolfe
General Topics/Tech Tips
May 28, 2015 10:57 PM
RidemyEVO
EVO
Feb 16, 2011 05:11 PM
freshman
Jun 15, 2010 05:12 PM
