I have been looking hard at Sportsters for my 2nd bike, and up until this morning I was settled on a 91-03 rigid mounted, carb bike for many reasons.
But this morning I started up my 1995 Dyna and let her idle for a while before I rode off. Even though the ambient temp was around 55 degrees the Dyna hadn't quite reached temperature and was really letting me know it. Spitting and sputtering and even backfired twice. Once she reached operating temp all was well.
That got me to wondering about fuel injected Sportys. Do they need the extended warm up time like the older Sportys and Dynas? I know the Evo Big Twins will blow rocker and base gaskets if you run them cold too many times. Is that an issue with the FI Sportys too?
I've owned several FI Twin Cams and I just started them up, let them idle 20 or 30 seconds to get the oil flowing then rode away. Never had an issue with them blowing rocker or base gaskets.
My 2 biggest reservations with the rubber mounted FI Sportys are-
1) They dont have the sound of a carbed bike. To me a carbed Sportster has one of the best sounding motors in HDs lineup
2) I dont like the look of the oil tank and the battery cover on the 04 and later bikes. But I could probably get past that.
No its stage 1 with air filter and V&H pipes. Otherwise, its almost all stock. However its a Dyna Big Twin. I'm just wondering if the FI Sportys will blow gaskets like the Big Twins and older Sportys do if you dont give them the long warm up time.
Carburetor been tinkered with for the Stage 1?
There is a pressure release in the cam plate for oil pressure and the vent system is big enough. I have never seen what you are saying as proven actually fact.
Like the myth that Synthetic causes oil leaks.
My bike starts and idles smoothly within a couple minutes. It's a carbed 1991 with 1250 conversion. No issues with cold motor driveability, but I baby my bike until it's up to proper temps, then I get on it. Perhaps your need to richen up your IMS?
I've heard this urban legend about blowing head gaskets, but I cannot recall ever reading about it here or over on xlforum.net. Of course, any fool that beats on a cold engine deserves whatever fate befalls them.
John
The warmup sequence is one of the best features of EFI Sportsters, the ECU "knows" the engine is cold (when it is) and adjusts the mix and idle speed accordingly as it warms up...no spitting, coughing, or stalling as it warms up. The owners manual suggests a 30 second warm up after a cold start so that is what I do and it works well. It is great not having to screw around with a petcock and choke unlike on my other 2 bikes...
Yeah the carb has been jetted. Idle jet was bumped to a 45 from a 42. I dont recall what the main jet is but it was bumped up too.
John
I baby mine until its warm too, and I never beat on it. I do enjoy a spirited ride through the back roads and twisties occasionally, but nothing I would considier close to harmful or beating it.
