Gas tanks
Old Jul 31, 2023 | 03:00 PM
sleighcrane's Avatar
sleighcrane
Default Gas tanks
I am looking at a 2007 sportster 1200. Is it difficult to fit a 3.3 gal tank where the 4.5 gal is? Will the stock seat work with it also?
Old Jul 31, 2023 | 04:22 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
The fuel tank mounting points are the same on all XL Sportster models from 2004 to 2022 regardless of the tanks capacity.
If you replace a 4.5 gallon tank with a 3.3 gallon tank, the smaller tank is shorter in length than the larger one, so there will be a gap between the rear of the tank and the front of the seat. the rubber breather hose outlet is mounted further forward on the 3.3 gallon tank, so you will have to use a longer hose than the stock hose on your 4.5 gallon tank.
Old Jul 31, 2023 | 05:28 PM
RKZen's Avatar
RKZen
Another consideration is the seat for the 4.5gal tank. You might want to consider a seat made for the 3.3gal tank as the seat nose for the bigger tank sits higher, and with that gap It might look a bit strange.
KIMORA 22
Apr 17, 2023 03:13 PM
Rojosanjo
Jun 17, 2022 02:28 PM
Wayne Gregson
Jul 1, 2020 08:36 AM
Hot
Mar 13, 2011 01:23 AM
Cycopath
Mar 10, 2010 08:15 AM
