Conversion question……
Old Aug 7, 2023 | 09:49 PM
Tromluihardtail's Avatar
Tromluihardtail
Stage III
Default Conversion question……
I know there are many threads about this but I can’t find the info I’m looking for. I recently bought an 883 that was said to have been converted. The head says 883 but when I put scope down the cylinder to look at piston it is stamped 3.625. It appears to be a standard flat top piston. There is also HH29 stamped on top of piston as well. I did the “stick” measurement and it looks to read as an 883. I’m lost. Any info will be greatly appreciated. It does have an S&S shorty carb on it.
Old Aug 8, 2023 | 07:56 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Said to be done and actually been done are 2 different things. Got any paperwork or receipts for parts or work done on it when ya bought it?
Old Aug 8, 2023 | 08:31 AM
Tromluihardtail
Stage III
No paperwork at all. 2 different people have owned it that I personally know but neither had the conversion done. It was said to be done by original owner. I did the “stick” measurement and it measures what appears to be stock stroke but with the pistons being stamped 3.625 I was thinking possibly a big bore kit was installed. I’m new to the conversion topic so I have no clue.
Old Aug 8, 2023 | 08:38 AM
Tromluihardtail
Stage III
I did forget to mention the pistons also have “valve relief” or “cups” on the pistons also.
Old Aug 8, 2023 | 10:58 AM
crb2855's Avatar
crb2855
If your talking about an 883 to 1200 or so the stroke is the same. The piston is larger in diameter in a bigger hole.
Old Aug 8, 2023 | 11:19 AM
John Harper's Avatar
John Harper
It's possible the combustion chambers were relieved to lower the compression ratio in order to use flat top pistons. I think the early SE kits had a template for grinding out material from the 883 chamber.
John
Old Aug 8, 2023 | 01:35 PM
eighteight's Avatar
eighteight
^ Correct
Old Aug 8, 2023 | 05:04 PM
crb2855's Avatar
crb2855
Someone has previously posted this but here it is again. You should read this it will explain the heads for an 883 upgrade. https://hammerperf.com/ttxlheads.shtml
RedLewy
Mar 22, 2018 11:12 AM
oo7ml
Jun 28, 2015 01:09 PM
vintagebikes
May 13, 2013 09:06 AM
ranger50
Oct 8, 2010 07:43 AM
jonny ebola
Sep 6, 2007 06:53 AM
