1 bearings are double row. I have not been able to find a 1 bearing with a width of 15mm.=(25mm bearing width)
I am currently doing a wheel swap on my 07 believe me, Ive been doing the research.
if you read ops post, he wants to know if a wheel from an 05 would fit his 08. You cannot use a 25mm bearing on a wheel that has 1 bearings. The 1 bearing is double roller. A 25mm bearing is single roller.
So unless he has a 1 axel to go with the 05 wheel, swapping bearings to 25mm id, , is not an option.
I think HD also has a kit for doing the same using just parts they supply.
Not sure it matters but the item youve shown claims for front ends.
Op is talking about rear wheel swap. And as I said, I am also doing a wheel swap and learning what I can and cant get away with.
63205-2RS Radial Ball Bearing Double Sealed ID 25mm x OD 52mm x Width 21mm may also help with using an old hub wheel that takes 21mm bearings on bikes that use 25mm axles.
