Starter continuously running
Old Sep 6, 2023 | 12:20 PM
Heritage_Luke's Avatar
Heritage_Luke
6th Gear
Default Starter continuously running
Hello,
2017 sportster 48 (no starter relay on this model)
My starter engages and runs continuously as soon as the battery is connected. I’ve been pulling the main fuse to kill power to the bike. I can hear the solenoid move(single solid click) as I put the fuse back in, so I’m leaning toward the solenoid not being “stuck”. I pulled the plug going into the starter and it has power even with the ignition and kill switch off. (See images). I would imagine it should not be live until these switches are on, and the start button is pressed.
my question is where to go from here? In my head, The starter receives a signal from the BCM so it’s likely the issue. I also have wondered if the right hand control module (where the start button is) is defective, and sending power when it should not be. If the right hand module is bad would the BCM automatically pass on the signal or should it stop it until all conditions are met?(ignition-on, switch-on, start button-on)
Thoughts?
please forgive my terminology, electrical work has always stumped me.
Old Sep 6, 2023 | 01:25 PM
RANGER73's Avatar
RANGER73
You're mistaken I believe.
Is the ignition off when this happens?
There's a starter relay of some sort somewhere, you need to find it.
Check your manual or follow the wire you pulled off the starter, It'll be on the other end.
Old Sep 6, 2023 | 01:43 PM
WP50's Avatar
WP50
If I'm looking at the right schematic the solenoid wire goes straight to the BCM
L2 Is labeled Starter Solenoid Power.
I'm sure surprised
WP
Old Sep 6, 2023 | 01:51 PM
RANGER73's Avatar
RANGER73
Old Sep 6, 2023 | 01:52 PM
RANGER73's Avatar
RANGER73
Old Sep 6, 2023 | 02:19 PM
TSheff's Avatar
TSheff
Welcome to the FORUM.
Old Sep 6, 2023 | 03:23 PM
Heritage_Luke
6th Gear
Yes, the ignition switch is off and it is still getting power. The only thing that stops it is disconnecting the battery or the main 40 amp fuse.
I’ve been unable to find a relay so far as it is difficult to chase wired without removing the tank. I read on other threads that the starter solenoid on newer models are controlled by a signal sent directly from the BCM. I’ll see if I can find out more when I get home from work today
Old Sep 6, 2023 | 03:47 PM
WP50's Avatar
WP50
https://serviceinfo.harley-davidson....d3ab603d!!1!71
This maybe small to see but here goes.
It's off of HD SIP for a 2017 Sportster 48
Red and Black wire goes from starter solenoid to Pin L2 for the BCM
Some of this new stuff is outta my park but I can read schematics most times LOL
WP
Old Sep 6, 2023 | 03:56 PM
Heritage_Luke
6th Gear
That looks right to me. I just have to figure out why/how it is constantly sending power. Wish I had a spare used BCM laying around to see if that solves the problem lol
WP
Old Sep 6, 2023 | 04:38 PM
WP50's Avatar
WP50
I maybe all wet on this but I 'm wondering if some input to the bcm says keep it cranking.
I couldn't find a start button in that diagram thou its gotta have one ___ don't it
Might try talking with a dealer or indy if you can and ask if they have seen this before.
Google was no help when I searched.
You might leave the solenoid wire disconnected at the starter then you can hook things back up and trace some of it anyway.
WP
