Basic 1250 kit
Old Sep 22, 2023 | 08:59 AM
Garry Sr's Avatar
Garry Sr
I don't want to nock Hammer but I went with the S.E. 1200 kit because it came with the heads.
Old Sep 22, 2023 | 09:08 AM
Garry Sr's Avatar
Garry Sr
My bike flies guys, my nephew was actually surprised when I lined it up with his Softail
Old Sep 22, 2023 | 09:11 AM
aswracing's Avatar
aswracing
883 heads have shallower chambers than 1200 heads, and the valves are longer to reach them. This puts the valves closer to the pistons to begin with, as compared to 1200 heads, and thus puts you in more danger of piston-to-valve (p-v) contact.
The operative cam specs for assessing your risk are the "TDC Lift" figures. These numbers describe how far the valves are open as the piston passes through top dead center between the exhaust stroke and the intake stroke. The higher those TDC lift specs, the more likely you are to get piston to valve contact. Whenever you run TDC lifts of more than about .200 on either valve, with stock 883 heads, you are taking a chance.
P-V clearance has nothing to do with max lift, as many people mistakenly assume. Max lift always occurs with the pistons well down the bore. It's the TDC lift specs that you have to be concerned about.
The N4's have TDC lifts of .216 intake and .189 exhaust. Although those numbers are totally fine for 1200 heads, in my experience they cause the pistons to kiss the valves about half the time when used with stock 883 heads. Many guys who are using them with stock 883 heads are getting contact and don't even know it, until they take it apart and see the marks in the valve pockets. It's often subtle enough that the only symptom is some excessive noise.
An alternative to the N4's, that's designed for a similar power band but has TDC lifts of .137/.150 and therefore are totally safe for stock 883 heads, is the Feuling 505/515 grind. So if you're looking for that kind of a power band (mid to top end at the expense of bottom end), that's the safer choice.
Old Sep 22, 2023 | 12:21 PM
Madnss's Avatar
Madnss
I don’t believe you’re knocking HP because you now have a stock 1200 Sportster pushing 70ish hp give or take. To each his own!
Old Sep 22, 2023 | 12:36 PM
MattLS6's Avatar
MattLS6
Man, I wish 70hp would get me all revved up. Would save me a lot of money.
Old Sep 22, 2023 | 12:51 PM
OCSpringer's Avatar
OCSpringer
How do you guys know your HP numbers? Dyno? Guess? I have no idea what HP my bikes running at. Heck, I don't even have a speedometer so I couldn't even tell you how fast I'm going at any given time. Ignorance is bliss. So when I get pulled over and the cop asks me "Do you know how fast you were going back there?", my only response will be "No sir, I do not. But it felt pretty fast"
Old Sep 22, 2023 | 12:55 PM
Garry Sr's Avatar
Garry Sr
They're going off the bone stock dyno sheet HD has posted. Hammer dyno'd the same kit if they look around.
Old Sep 22, 2023 | 01:02 PM
Garry Sr's Avatar
Garry Sr
The Hd generic dyno sheet is conservative but the bike still isn't putting out anything I'd call amazing
Old Sep 22, 2023 | 01:26 PM
MattLS6's Avatar
MattLS6
Dyno. I never get too caught up into the numbers though since there's so many variables (i.e. different dynos read different, dyno operators can manipulate things, tire pressure and belt/chain tension can change things, etc.). Trap speed at the track is where I like to get a feel for the actual real world performance.
To the OP, Aaron's post is about as good as it's gonna get, he's a wealth of knowledge. A friend of mine has those Feuling 505/515 cams in a 1200. They will hit later in the rev range than the stock W cams will. Depends where you want your power. W cams ain't bad for a lot of people, I'd go with the 505/515s if you like to run it hard. The 1250 kit alone will make a dramatic difference coming from a 883.
Old Sep 22, 2023 | 04:18 PM
Madnss's Avatar
Madnss
Dyno and drag strip for my hp numbers.
