Engine races
Old Oct 20, 2023 | 06:36 PM
hammer6315's Avatar
hammer6315
Default Engine races
2008 Sportster 1200: Today while on a ride, the engine began to race, like ~1500-2000rpm with the throttle closed. I shut the engine off and re-started it, but the condition persisted. Later on, the rpms settled down to a reasonable speed. Any ideas? Thank you! (Has anyone installed a Barons Brand Tach on their Custom, and is it difficult to wire?) Thanks again.
Old Oct 20, 2023 | 06:44 PM
John Harper's Avatar
John Harper
Idle Air Controller? That would cause a hanging idle. Maybe take it out and clean it. An old GF had a Honda that had a constantly fluctuating idle, after cleaning the IAC, no more problems. Check for any codes afterward?
John
Old Oct 20, 2023 | 10:30 PM
hammer6315's Avatar
hammer6315
IAC, suppose I'll have to do my homework and see where it is located. Codes? Again, I'll have to read up on the procedure to access them. Thank you.
Old Oct 21, 2023 | 06:30 AM
Bubba Zanetti's Avatar
Bubba Zanetti
John
This^^^.
OP, check you tube. There’s probably tons of videos to walk you through it.
Old Oct 21, 2023 | 06:59 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
It is located on the throttle body. You should be able to see the wires going to it below the tank.
Old Oct 22, 2023 | 02:56 PM
hammer6315's Avatar
hammer6315
Thanks. Only code I found was under the SP: b 1006
Old Oct 22, 2023 | 10:57 PM
hammer6315's Avatar
hammer6315
After some research, think I'll load check the battery, and the charging voltage. Then delete the code and see if'n it returns.
Old Oct 23, 2023 | 06:46 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
It's perfectly normal for EFI Sportsters to have a fast tick over from a cold start, my 2011 XL883N starts at 2000rpm from cold, after about three minutes it settles down to a regular 1000rpm.
This is the first time I've heard of a Sportster tick over racing when the motor is at working temperature, good luck curing your problem.
Old Oct 23, 2023 | 08:31 PM
dsc2's Avatar
dsc2
6th Gear
Had the same symptom on my 2015 1200T, was the intake gasket leaking.
Old Oct 23, 2023 | 08:36 PM
John Harper
That could do it too!
John
rowdytoad
Apr 7, 2023 03:30 PM
BobRR
Jul 13, 2019 09:07 AM
hunter28x
Engine Mechanical Topics
Jul 16, 2014 07:55 PM
Red Dragons
Oct 4, 2013 05:21 PM
Cromosappien
Oct 20, 2011 09:54 AM
