Choke relocation bracket
Old Dec 3, 2023 | 07:44 PM
OCSpringer's Avatar
OCSpringer
Which choke relocation bracket are you looking for? The one that mounts to the carb top?
Old Dec 4, 2023 | 02:55 PM
Imp of The Perverse's Avatar
Imp of The Perverse
Yes, not available in the UK!
Old Dec 5, 2023 | 03:44 PM
John Harper's Avatar
John Harper
Okay, I bought one for you, and will send by US Mail as soon as I receive it.
John
Old Dec 5, 2023 | 06:32 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
John
That's a very kind gesture, John.
The bracket is a very simple design, once the dimensions are known, it would be very easy to make one out of a sheet of 10 SWG (3mm thick) stainless steel.
Old Dec 5, 2023 | 06:52 PM
John Harper
He's reimbursing, so not that noble a gesture. Someone had to help him out on this.
John
Old Dec 5, 2023 | 07:14 PM
Rob Roy's Revenge
John
It's good that you took the initiative to help him out on that one, John.
Are you sending the bracket as a letter post without the extra long screws? The screws will be easy to sourse in the UK as they are M4 thread on the top of the stock Keihin CV carb. If memory serves me right, the stock length is 14mm, with the bracket a couple of 16mm or 18mm long screws will be required.
Old Dec 6, 2023 | 07:40 AM
John Harper
Yes, I was going to send just the bracket, I expect the screws are easy to find in the UK. The flatter the envelope the better I would guess. I'll measure the screws when it arrives so I can let him know. Luckily the bracket is aluminum, not steel, so it should be very light.
John
Old Dec 6, 2023 | 07:55 AM
TexasScooterTrash's Avatar
TexasScooterTrash
So ya can't buy one. Nothing is preventing you from making one. Don't have the dimensions, measure it. Make a thin cardboard template of the bracket, using the top of the CV-40. Get a small piece of steel and cut it to fit. Necessity IS the Mother of Invention.
Old Dec 6, 2023 | 03:55 PM
John Harper
Not everyone has the tools or workspace to do this. Simple as it sounds, it's not like cutting out paper doilies with safety scissors.
If all goes as planned, probably $15 total and he's good to go. And, we took care of a new member from across the pond.
John
Old Dec 8, 2023 | 05:01 AM
Imp of The Perverse
I do all my maintenance outside I live in an apartment.
