Starting issues
Report back with the codes you have.
That last question, your tipover sensor is called a bank angle sensor (BAS) Most Harleys', it's in with signal light blinker and alarm if equipped, module. It resets ever key off and on. Would not think it would even crank if that was bad.
Have seen them go bad or not be mounted in correct firm position from users on here.
Would like to add, and only as a suggestion, make your next new post over in the new member welcome area to say hello.
And of course..
Welcome Joker.
Hope you continue to enjoy your ride here with us on the HDFORUM.
Only as a suggestion, but very important, create a signature line similar to mine with your year, model, and all the letters Harley assigned to your bike. It will appear at bottom of your post.
You can also add a favorite picture to the signature line.
Doing this will be helpful if you ask a question or someone asking a question. All Harleys aren't the same with many changes and variations over the years.
You can also add a favorite picture for an Aviator postage stamp you see at the top left of your post.
Here you can see that part.
https://partsfinder.onlinemicrofiche...avidsonmc/722#
sensor, the crank postitioning sensor, fuel regulator, fuel pressure regulator, the fuel rail and hose, the injectors, fuel positioning sensor, one o2 sensor, fuel pump, the fuel filter and housing, rewired the fuel pump assembly, the fues rnt blown, or dirty, i have checked the pins in the ecm, the connector is secure, and not dirty, i am so lost rt now that it is driving me nuts.
Put the run stop switch to run and see the check engine light come on. 4 seconds later it should go off.
If either of those light stays lit you have stored codes.
Why did the fuel pump need rewiring?
I can't help but think now there is so much you are not telling us amongst just guessing at anything.
At this point you need to find someone who has HD experience.
You have guessed and failed and already I assume spent out money, possibly wrongly.
The tank shouldn't be pressurised. Maybe the vent is blocked?
Have you also checked the 2 relays are good. You need to do that on the bench to make sure the contacts when closed are not high resistance.
