The clevis that the brake pedal pivots on and the footpeg mounts to is held in place with a socket head cap screw. Question I have is, there is a snap ring on the end of the clevis facing the motor. What purpose does that snap ring serve since the socket head is actually holding the clevis in place?
Seems kinda redundant IMO, and serves no real purpose other than to make it extremely difficult to remove/replace the brake pedal and or footpeg. I can't see any problem with just leaving the snap ring off, or is there something I am totally missing?
While this image shows two footpag celvis pins, the Sportster only has one on the right side. The larger of the two snap rings fit the groove in the clevis which is on the back side (facing the motor). As shown the socket head goes thru a hole in the footpeg mount and threads into the clevis locking it into place. So what purpose does the snap ring serve? To me it appears nothing...
Whenever you pull a snap ring or cotter pin you best make sure to put it back as I am sure it's there for a reason. Safety features are often redundant.
Safety feature just to make sure you don't lose your brake peddle..
I suppose so, that's why I said I feel it is redundant. If the socket head cap screw that holds the clevis in the footpeg mount backs out and falls off you will lose more than just the brake pedal, you would have no footpeg either. Actually, the brake pedal would be dangling by the rod that would still be attached to the master cylinder.
I'm going to live life on the edge and leave the snap ring off...
