Ok so i did some parasitic drain testing first by disconnecting the - of the battery and hooked a meter between it.
When the bike is completely off, it still drains a 11ma if im correct (?).
What i did noticed, was every time i hook the - back again to the battery, i hear some minor mechanic noises (like pumping or rotating) coming from behind de air filter box. Not really sure if thats normal or something there is making a short?
I will Check where the exact drainage comes from in a few weeks tho.
Don i own the bike now for over 1.5 year and im on my third battery now.
ut.
To state the obvious something is not right. I would check the charging system, and maybe even the tender. Maybe disconnect the battery after a ride, and see if it start in a few days.
See that there is 14.4is dc volts on the battery when you rev the bike up to around 3k rpms.
Originally Posted by Andy from Sandy
That if I am correct is the idle air control valve. It is some kind of stepper motor that the ecm resets when power is connected.
Yes you can duplicate it by cycling the power with ignition.
Is your bike a Europe bike?
Some bikes in certain geographic areas have extra pollution control stuff
If you continue to hear noise after shut-off for more than a few seconds there might be a concern.
At connecting power not so much a problem.
* Many aftermarket batteries require the use of brass color spacers at terminals if the wires are side mounted since the battery terminals are not flush with side of battery case.
Some riders forget to install with the spacers and then the contact is poor.
Poor contact leads to poor charge and poor starting.
I did tested that before by fully charging it, and left it off the charges for 3-4 days. The bike wouldn't start tho i havent started it after disconnecting. So it seems not related to the charging system.
I do believe now that there is some drainage which i will find out in few weeks. Im not very technical myself when it comes to electricity, so my dad will help me out with this.
With his 2017 bike the cable terminals are not flat and are bent at 90°, they don't hang down like on 2013 or older bikes. Even with the terminals on the battery set back it doesn't require spacers.
Its a HD1 bike, but i live in The Netherlands.
If the battery is disconnected from the bike, reconnected, and doesn't start, it is a bad battery or was not charged.before parking.
Back to earlier comment about IAC motor noises, that is on start up, not when shutting down, that I have ever noticed. But as said maybe you got some other pollution control device.
It does start after disconnecting. Also after riding. It simply seems to drain after a few days when not riding.
I hear that noise only when i disconnect the battery and than connect the battery again. Its noticiable after connecting the battery
