Battery issues?
Old Apr 14, 2024 | 03:02 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
In simple maths I work out that if you can perhaps take 3 amps out of a 12 Ah battery and still leave enough for a start but only guessing it ought to last 11 days.
3 / 0.011 = 272 hours = 11 days.
0.011 Amps is the current draw seen with the bike off.
This is the expected time a battery should not need charging but it will need charging after starting the bike as it will be at a low state of charge. If the battery doesn't get fully charged now there is a chance it may not start the bike reliably. All guess work here. Don't shoot me only come with more facts for the OP.
Old Apr 14, 2024 | 04:07 AM
ramon.schriks@gmail.com's Avatar
What i do notice is that, when charged fully with a charger, when i start the bike, it doesnt seem to crank really fast as stated in the opening post.
It cranks once or twice, then pauses like the next crank takes ages. After that crank it does start immediatelly.
The battery is full at this moment, but when i compare to other videos of forty eight's starting, they crank fast and consistent and start almost instant.
11 days is not what im getting out of is, at most 4-5, but it drains 0.011a when off. So might this mean that the battery itself might be not good?
Old Apr 14, 2024 | 08:20 AM
Rounders's Avatar
Rounders
Originally Posted by ramon.schriks@gmail.com
It does start after disconnecting. Also after riding. It simply seems to drain after a few days when not riding.
I hear that noise only when i disconnect the battery and than connect the battery again. Its noticiable after connecting the battery
Is the noise the same as when you normally turn the bike on and off? Fuel pump pressurizes, sometimes if quite you will hear the various electronics wake up.
If a bike is starting slow it is usually the battery, if the cables are tight. Do you have a charger with multiple settings or a jump pack? See if it starts faster after being on 10 amp charge for 5-10 minutes, don't leave it on high
Usually how I know I will need a new battery is listening to how it starts, but I have also been listening to these bikes for years. You could have it load tested.
BadDogBiker
Sep 11, 2021 12:57 PM
natedog_37
Oct 18, 2016 08:39 AM
Titan307
Oct 17, 2013 09:30 PM
paud
Sep 5, 2012 05:36 PM
Modee1245
Mar 5, 2008 09:09 AM
