Installing longer rear shocks
Old May 12, 2024 | 12:55 PM
TwoBlue02's Avatar
TwoBlue02
Default Installing longer rear shocks
PO had put in 1 or 2 inch shocks. I am trying to re-install the originals. I searched a bunch of ways but could never find anything as to how to do this.
Help is appreciated!
Old May 12, 2024 | 01:14 PM
John Harper's Avatar
John Harper
What year and model? What length shocks do you have, and what do you want?
John
Old May 12, 2024 | 03:09 PM
TwoBlue02's Avatar
TwoBlue02
Duh! 2003 1200 standard. I have the OEM shocks which are 13.5, installed ones are 11.5
Old May 12, 2024 | 03:21 PM
John Harper
There should be no problem, all the Sportster frames are the same 1991-2003. I have 13.5" Burley Stillettos on my 1991 Standard model. I believe OEM shocks were 13.25".
John
Old May 12, 2024 | 04:12 PM
perki48's Avatar
perki48
Just take off the short set and put on the stock ones, simple as that.
Old May 12, 2024 | 05:03 PM
TwoBlue02's Avatar
TwoBlue02
Holes don't line up.
Old May 12, 2024 | 05:27 PM
John Harper
You will probably have to lift the bike on it's frame, pull both old shocks, and lift the bike up to get the longer shocks to fit, leaving swingarm and wheel on the floor. It's pretty easy with a lift, especially since you need to get the back of the bike up at least 2". Without a lift, could be tough. A long wedge shaped piece of wood is also good for lifting the rear wheel/swingarm for fine adjustment of the hole spacing.
John
Old May 12, 2024 | 10:31 PM
perki48's Avatar
perki48
I'm guessing about 2" off.......................Do as John said.
Old May 13, 2024 | 09:59 AM
Madnss's Avatar
Madnss
because you have to take the short shocks off then install the long ones. Is there something I’m missing here or wat?
Old May 14, 2024 | 09:31 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Do you know if the front forks were lowered as well? If so, and you install the taller rear shocks, they might not play well with the lowered forks on the front.
