Starter
Old Aug 30, 2007 | 11:24 AM
rmxlr's Avatar
rmxlr
6th Gear
Default Starter
Has anyone had trouble with the starter clutch? Had mine go on an '04 roadster and the bike has less than 20000km. I think thata starter should last much longer and have never had trouble with a starter on other vehicles.
Old Aug 31, 2007 | 05:48 AM
bigtop1's Avatar
bigtop1
Default RE: Starter
Not sure what your problem is. Starter or clutch? Starters are pretty dependable but, I have had problems with them from time to time. The usual problem is that the solenoid will hang up and not engage the flywheel to turn freely. When you go to start it, the starter will drag and, unless you have a really powerful battery, it will not want to turn over the engine.You then begin to wonder if its the battery or what. A bench test of the starter will indicate the resistance flow.
Old Aug 31, 2007 | 08:14 PM
rmxlr's Avatar
rmxlr
6th Gear
Default RE: Starter
The dealer told me they replaced the starter clutch. I'll look up the part number on the work order. It is the thing that lets the starter gear run only one way and free run the other. Starter drive? Anyway, Harley calls it the "starter Clutch".
Thanks for the reply
reddog#1
Sep 16, 2012 07:16 PM
lebert
Aug 7, 2010 07:03 AM
boneyrooster
Jun 16, 2010 08:39 PM
Bullys FLSTN
General Topics/Tech Tips
Jul 20, 2008 07:50 AM
02glide
Oct 26, 2006 01:00 AM
