Air cleaner recommendations
Old Sep 22, 2024 | 10:17 AM
  #31
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Bubba Zanetti
So where is the oil going in that position? If it’s mounted below the air filter the oil will flow down.
In that position it looks like the misty air would be filtered and escape but wouldn’t the oil just sit in the tubes now ?
Originally Posted by Andy from Sandy
I concur and this from DK doesn't make sense, "The one main advantage of routing the hose and filter above the air cleaner would be having gravity on your side." in my opinion.
The misty air as it condenses will leave oil in the pipe close to the breather exit.
The only time that there would be a problem routing the hoses up is if there were lots of short rides, especially in cooler weather, with no longer rides sprinkled in the mix.
When the engine is fully heat soaked, the oil and condensation that accumulates in the hose and breather channels will get vaporized and evacuate via the filter or catch-can or open hose.
But if the engine never gets ridden for any distance, fully warmed up, then routing the hoses up will result in them filling up with a combination of oil and condensation. This will not cause any engine damage, this gunk will not go back into the engine oil, but it will eventually fill up the hoses if the engine is never run to full operating temp for a period of time.
Here are photos of a couple of my bikes that have the hose routed up. Both of these bikes see lots of shorter runs in cooler weather, but they also both see longer rides of an hour or more on a regular basis.
Both of the photos above are of the Stealth EBS that can be seen at this LINK.
Kevin
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 22, 2024 | 10:49 AM
  #32
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by tempocyclist
I have my breather filter mounted directly above, I assume this is fine?
It's a recent addition (thanks to DK Custom of course).
I did it that way mostly because it looked good, but I could easily move it below instead if that is "better" for the escaping air/oil/whatever?
Yes, you are good to go with either set up...unless you rarely run the bike at full operating temperature...in that case, route the hose down.
Kevin
chief1600
Stock Harley Take Offs
Aug 10, 2022 06:13 PM
dakotav8
EVO
Oct 26, 2016 11:53 AM
m1crazy
Aug 26, 2011 06:21 PM
dowork08
May 9, 2008 04:21 PM
Sleeps In Trees
Jul 22, 2006 10:50 PM
