Drive belt replacement
Old Sep 28, 2025 | 08:51 AM
firehawk6's Avatar
firehawk6
Default Drive belt replacement
Is there a time or mileage when it is considered a good time to begin thinking about swapping out the drive belt for a new one?
My 883 SuperLow is pushing 41,000 miles, and while I see no damage to the existing belt, should I consider replacing it just to be 'safe'?
Old Sep 28, 2025 | 08:56 AM
Ohio HD's Avatar
Ohio HD
Belts that are kept in proper tension, and inspected and or cleaned of any debris would last a long time, speaking like 100k miles. That being said, unless you ride dumping the clutch, etc. to shorten it's life. Inspecting the pulleys for wear chipping, etc. is also part of the inspection.
OCSpringer's Avatar
OCSpringer
If there is no cracking or fraying of the belt I would say it is fine.
Old Sep 28, 2025 | 10:08 AM
Rounders's Avatar
Rounders
A belt will last a long time. But when it goes, it could leave you stranded waiting for hours for a tow, Miss work, ect As for inspecting, how many are giving a detailed inspection frequently. I suspect most people just do it when they change the tire. Most are not jacking it up and rotating it every 1k miles, who has that kind of time? A lot can happen in 10k miles.
A harley mechanic told me every 50k is recommended, I had one go 55 and another I replaced at 90. My opinion about most maintenance items on harley is 50-70k miles. At 50 it is a good to start thinking about when would be a good time for you do it, time and money. Yes, that is a broad window.
Old Sep 28, 2025 | 07:06 PM
Ghetto blaster's Avatar
Ghetto blaster
I had 80,000+ miles on my Sporty 0 issues.
Old Sep 29, 2025 | 03:20 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The rear pulley being chrome plated alloy is possibly the weak link. It may chip leaving a sharp edge.
The belts are a boon compared to a chain, IMO. My partners trike conversion is a very heavy Sportster yet the belt has barely stretched in the 7 years and 43K miles she has had it.
Old Sep 29, 2025 | 04:59 AM
eighteight's Avatar
eighteight
Not a difficult job on an XL
If it makes you feel better, change it
Old Sep 29, 2025 | 05:12 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
As long as the belt looks ok, you should be good up to the 100,000 mile range.
The original belt on my `89 Softail lasted 115K.
Old Sep 29, 2025 | 05:19 AM
touchdown's Avatar
touchdown
This I just don't know. My bike has over 66000 and still looks good. I was thinking even if it looks good at 80000 I'm going to change it.
Old Sep 29, 2025 | 07:26 AM
Architect's Avatar
Architect
I have never changed a rear belt due to age, if it still looks good, carry on. Now if you have the primary apart for other work and the belt is in your hands, cheap insurance.
