Fluids...
Old Sep 8, 2007 | 11:30 PM
Mark g's Avatar
Mark g
Default RE: Fluids...
I filled mine threw the inspection cover made it real easy.
What lubes are you using?
I used Mobil 1 20/50 V-twin full syn in the motor
and Mobil 1 75/90 syn gear oil for the clutch and primary
All is working well.
permatex makes a product called never seize. any auto store should have it. Good for exhaust nuts and 02 sensors as well
Old Sep 8, 2007 | 11:43 PM
6o66er's Avatar
6o66er
Use a set of vice grips.
Old Sep 9, 2007 | 12:07 AM
jackofhearts's Avatar
jackofhearts
Hi, my 5K service is here and I want to change the primary/trans fluid. The manual only gives HD part number, not SAE specs. I jotted down this from another forum for later thinking I would come back to it, as it appears to have something that I could learn about smoothing out the tranny shifting...
"Bel-Rey 85W140... Hayden M-6..." What can these procucts do for my 05 1200C, and who has this stuff. Anybody know the type of fluid I need, SAE numbers/type, not HD. thanks Wondering where you got the 75/90 numbers.
Guy M
Old Sep 9, 2007 | 12:35 AM
Mark g's Avatar
Mark g
lots of info on oil and brands in the oil forum.
There is even a pole on who uses what, seem's the mobil 1 V-twin is the most popular, followed closely by amsoil.
75/90 gear lubeis equivalent to 20/50 motor oil , either are viable for the clutch/primary.
I'm about 600miles past the change and i'm very satisfied with my choices
Old Sep 9, 2007 | 07:04 AM
cHarley's Avatar
cHarley
ORIGINAL: jackofhearts
Guy M
For your primary/tranny go with a 75w-90 gear oil like Mobil-1 syn 75w90. Stay away from the "heavier"85w-140 gear oils. They only work in the BT's which have a seperate tranny and primary. You have to be careful when reading some of the other forum topic areas here in that the Sportster primary/tranny is different.
Old Sep 9, 2007 | 10:48 AM
Nick's Avatar
Nick
I used the mobil 1 20w50 for the oil and tranny went with the 75w-90 I will let you know what I think when I get my gasket hopefully today
Old Sep 9, 2007 | 10:54 AM
twisty571's Avatar
twisty571
just did my 5K and used Valvoline SynPower Full Synthetic 20-50win both[8D] It was on sale for $6 a bottle but it was buy 1 get 1 freeeee
Old Sep 9, 2007 | 11:15 AM
cHarley's Avatar
cHarley
Up until the last few years, HD recommended Sportrans fluid in the Trans/Primary. The Sportrans fluid was a gear oil. Recently (for convenience?) HD has been saying it's "OK" to use 20w50 engine oil in the trans/primary. I'm now reading that HD is backing away from saying that the engine oil is the best fluid choice for the gear box. It kind of makes since,the engine and tranny are 2 different environments. I'll stay with using Gear Oil in the gear box. Just my .02.
Old Sep 9, 2007 | 11:21 AM
twisty571's Avatar
twisty571
ORIGINAL: cHarley
I have been debating that myself and do worry about it,I had them do the 1K service and they swapped it to full syn then.The other thing I heard is I shouldn't go back to regular stuff after going to full syn.????
Old Sep 9, 2007 | 11:37 AM
cHarley's Avatar
cHarley
ORIGINAL: twisty571
ORIGINAL: cHarley
There is no reason to go back to dino "regular stuff". Mobil-1 75w-90 Gear Oil issynthetic. It's $9 and change at AutoZone. Other comparable products are available from Redline, Royal Purple, Amsoil etc.
